Question about Philips SA3285/02 Digital Media Player
GoGear Capacity problem
Hi The memory of my gogear sa3285 is full so when i turn it on he refuse to work and it tell me that i have to free space and connect to a computer. But Computer can't recognize the pilot driver since it is full.I have tried to delete the driver and reinstall it but same situation. I also tried to another computer same situation. How could reformat the gogear or how it would be possible to fix the situation Thank you very much
    Problem Solver:
  • 5 Answers
Are you able to delete songs in the MP3 player itself? If so, try deleting some and then try connecting again.
Posted on Jun 01, 2009
How can I use a Philips GoGear sa3285 with a Mac laptop?
Contact Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 10, 2015 | Philips 8gb gogear sa3285-mp-3 portable...
My philips gogear mp3 vibe sends the message "must
First of all have you loaded the gogear from the philips media converter and is the whole space filled up. In some cases there must be a space on the memory as the system may work very slow if the memory is full. Try and delete some files in this case. Also load only safe files that are scanned and has no malwares.
Hope you try this out.
Oct 19, 2011 | Philips GOGEAR SA6045 MP3 Player
Hi, I am using Philips Go Gear 4 GB MP3 palyer. It has 3 GB free space but when I start the player,below message comes . Please tell me how to solve the issue "Memory Full Connect to PC &...
Possible that some of the files in the GoGear are not to the requriement of the player. So download the media converter and download the files to be transferred to the player. In the first place connect the player to the PC and move OFF all the files , delete the memory to be free and then reload using the converter .
Use the link below:
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA3104-SA3105-SA3114-SA3115-SA3124-SA3125-MP4-Player-Media-Converter-Software-1-0/
Mar 18, 2011 | Philips GoGear HDD1830 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
My 8G Philips GoGear SA3285/37B is saying i have no memory left when i've deleted everything on it, music and all. how do i fix or reformat it?
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you try to restore factory setting using Device manager or repair it using Philips songbird or device manager.
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Feb 15, 2011 | Philips GoGear Flash MP3 Player
It will not let me add videos any more and my memory is not full i still have space
I recommend you to reset your device If the solution above didn't solve the problem :.
Take a small object like a paper clip and use the edge to stick into the small reset button on the side next to the usb connection .
Or Try [ power + volume up button & hold for 3 seconds ]
Your mp3 player has two types of memory in it. The hard drive (where the music and photos are stored) and the Ram (where the firmware and active files are temporarily hosted).
When you soft reset your GoGear, it flushes the RAM, and restarts the operating system (which is why the contents of the hard drive does not get erased).
You can "hard reset" the device, by formatting the drive and resetting it to factory defaults in the Settings field. This is the closest thing to a "hard reset: that's available with an HD based MP3 player.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GOGEAR SA6045 MP3 Player
Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
Nov 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips SA3285/02  Digital Media Player Logo
295 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
