Question about LG KU990 Viewty
Fiesta 2001 driver's wing mirror
I'm trying to replace the whole of my driver's side wing mirror on my ford fiesta 2001. I've got the replacement and am struggling to get the door frame off the door. I've taken off the door handle and window winder but can't unscrew the screw in the pocket of the door. please help, what can i do to get the fame off?!
  • 4,889 Answers
It's basically a case of taking the door panel off! (This is for driver and passenger sides). Firstly remove the screw holding on the black plastic cover where the mirror adjustment control is and remove the black plastic surround. There is also a circular piece of plastc behind the mirror adjuster, make sure you remove this (turn anticlockwise) otherwise you won't get the mirror out later on! Next remove the screw from the door bin, inside the recess in the arm rest part of the door panel and from behind the door handle surround. Carefully slide the door handle surround off (first towards the front of the car and then towards you). Once the surround is off carefully unclip the speaker wire from the back.
Once you've done all this you are ready to go - the door panel itself is held on by plastic poppers, there are around 2 either side and 3 at the bottom. Carefully unclip all of these so that the panel is loose. Then slide the panel up (there is a plastic fitting at the top of the panel which sits in the gap where the window is). The panel will now come away - be careful not to rip any of the thin foam like lining of the panel and also of the wires going to the speaker.
There are 2 more screws which hold the wing mirror on - unscrew both of these and the wing mirror will now come off. Make sure you keep the sponge padding as you will need this to help you hold the new mirror controls in place. Then its quite simply a case of fixing the mirror on with 2 screws and refitting everything in reverse of taking it off.
Posted on Oct 23, 2007
Removing wing mirror electric on ford fiesta 2003 1400 zetec right hand side
Ooh..! It was a great idea. Its an innovating idea. you just careful while doing this or I recommend a mechanic to do this
Aug 05, 2016 | Ford Cars & Trucks
How to replace wing mirror
The door panel must come off, in the video they call it a door "card" the video deals with a retrofit to upgraded but the door panel instructions are great on how to remove it.
Ford Fiesta MK7 2008 2012 Door Card Removal Powerfold Mirror Fitting Guide
May 30, 2016 | 2013 Ford Fiesta
Ford Fiesta Wing Mirror Fix (not replace)
Hi Steve
A mate of mine had a similar problem and he said he got in touch with a place called wingmirrorman.co.uk, They sorted out the bits he needed as he didn't have to replace the whole thing.
Jul 16, 2012 | Ford Fiesta Cars & Trucks
How Do I replace the glass in a Feista 2009 wing mirror
I'm assuming it is broken, You have to pry the rest of it out with a screwdriver. It is held on with double sided tape. If you replace it with the tape it will have to be in a warm place, it doesn't stick to well when it is cold. If you use silicone you have to get a special silicone that does not bleed thru the mirror. silicone it on and tape it in place. leave the tape on for a day
Nov 18, 2010 | 2011 Ford Fiesta
Right wing mirror hanging off 200 Ford Fiesta
you will need a new mirror assembly. Buy a used one at a salvage yard or ebay
Dec 26, 2009 | Ford Sport Trac Cars & Trucks
The wing mirror on my ford fiesta is broken in half
Check at a breakers yard you may be able to find a suitable replacement with mirror intact for less than a new on can be had. Or check a glass shop to see if they can cut a replacement to the size you require.
Jul 08, 2009 | Ford F Cars & Trucks
Replacing passenger wing mirror on ford fiesta finesse 2000
yes it is better to remove the whole panel, the panel slides down over the top of the frame of the door. remove the clips on the door carefully though as when these clips get old they become fragile and snap quite easily.and then remove the secondary panel for the mirror.
Apr 30, 2009 | 2003 Ford Escort
Wing mirror replacement Fiesta
on the inside of car remove plastic triangle then you will find 3 screws remove these and refit
Mar 19, 2009 | Ford F Cars & Trucks
How to replace wing mirror on my ford focus.
on the inside of the car in the corner of the door is a blck plastic piece remoce that and you should see a couple of screws(think they where starbits last i checked) take those out and then you should be able to remoce the mirror from there.-z
Feb 20, 2009 | 2001 Ford Focus
How to replace the door mirror @ drivers' side of ford fiesta
look for fasteners on the outside if mirror where attaches to door ,if none take door cover off
Feb 06, 2009 | Ford F Cars & Trucks
LG KU990 Viewty Logo
2,845 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
