Question about Imperial IFS40 Deep Fryer
Burner will not come on
Imperial 40lb natural gas fryer. The burner will not come on. the pilot light stays lit,but goes out instantly when thermostat is turned on.
    Problem Solver:
  • 6 Answers
Need tochange termal couple
Posted on Jun 01, 2009
Imperial gas fryer burner wont light
Check out the over heat is not shutting down to soon or thermostat is not opening ,
Sep 01, 2012 | Imperial IFS40 Deep Fryer
At 300F after half hour, pilot and main gas burner was going off. When re-lit would stay on only 5 minutes thereafter. Had the thermopile changed(bought locally- not original from Imperial but identical),...
Hi there.
The thermostat will only shut down burner flame but not pilot flame.
Try tightening all wiring connections.
By using an ohm meter, check the continuity across the hi limit terminals when the pilot goes off, your hi limit may be tripping prematurely causing pilot flame to shut down.
Regards.
Jul 29, 2011 | Kitchen Appliances - Others
I JUST BROUGHT THIS IMPERIAL DEEP FRYER AND I WANT TO CHANGE FROM NATURAL GAS TO PROPANE GAS.
You will need a conversion kit from natural gas, most of this kit contains gas valve spring, burner and pilot orifice. Check the nearest authorized dealer in your area and ask buy the appropriate conversion for your fryer.
May 28, 2011 | Imperial IFS40 Deep Fryer
Pilot won't stay lit
If a standing pilot won't stay lit, the usual cause is a bad thermocouple. The thermocouple is a safety device with a probe that is kept heated by the pilot flame and produces an electric signal. Wires from the thermocouple connect to the main gas valve. If the thermocouple fails, the main valve shuts off gas to both the pilot and main burner. When you try to re-light the pilot, it goes out again as soon as you release the pilot button on the valve.
A new thermocouple is only $10 or so, and it's pretty easy to change. There are a number of how-to sites and videos showing how to change the thermocouple in gas furnaces and water heaters, and the process is similar in commercial ovens and fryers. Once you see what the thermocouple looks like and how it's installed in some other appliances, you'll be able to identify it in your fryer and see how to change it. That should get your frying again.
Dec 28, 2010 | Imperial IFS40 Deep Fryer
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Imperial deep fryer IFS40 pilot lights, turn on gas valve main burners come on run for awhile then everything shuts down main and pilot. You can disconnect the thermostat and the same thing happens, main...
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Feb 18, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Imperial IFS40 Deep Fryer Logo
265 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
