Question about Honda Pressure Washer PSI 3000
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
Won't start until it cools off..What is happening? I have the same problem but now even cold it won't start & no spark to plug.
  • 174 Answers
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Posted on Jun 16, 2009
Volvo Won't Start
Replace your spark plugs and spark plug wires. This will probably fix your problem. Be sure and check your firing order in case one or more plug wires are hooked up wrong. This sounds like it might be your problem.
Feb 09, 2018 | 1984 Volvo DL
Hello, Car will start until warm then shut off then won't start again until cool then same thing happens over again
As with any no start issue you will need to figure out if you are dealing with a no spark or no fuel problem to proceed. Check the plugs for spark and the fuel pressure the next time it will not start.
Could be a faulty relay, ignition module, coil or other electrical component.
Let us know what you find.
Aug 13, 2012 | 1999 Chevrolet Monte Carlo
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
Hitachi CS33EB won't start when hot solution?
see if you loosing spark when it doesn't start
Aug 10, 2012 | Hitachi Garden
On hot days...the engine sputters and eventually quits...won't start until it cools down.
My first guess would be a relay or the ignition module.
Do you have spark at the plugs when it won't start ?
Jul 10, 2012 | Ford Taurus Cars & Trucks
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
1991 Toyota Celica, after running at temp. won't restart until it cools down. I don't thing the radiator fan is running. Also, it won't even crank, all the dash lights come up like usual but...
Usually that happens when the ignition coil gets hot. Not sure if your car has one. It looks like a round cylinder with a spark plug wire connected to it.
Nov 17, 2017 | Toyota Celica Cars & Trucks
1996 jeep grand cherokee w/ new rings,rod bear.,valve job,rad. & water pump and transmission. now just shut down in middle of highway when accelerating or slowing down. engine light now on. whats up?
COMMON PROBLEMS
There are several things that few people know about starting cars in cold weather. 1. Check your battery to make sure it is not rusted, leaking, and has a charge 2. Jump start your battery with another car, even if you believe the battery is good, this often times will still start your car. 3. If your engine is cold, and you have an older car, ensure to get your fuel lines to the engine flushed or have fuel injection service performed 4. The engine tends to warp the same way wood does during the extreme cold, do not be afraid to continue trying to warm up the engine by constant cranks with it is cold out. Your not going to hurt the car, the worse that could happen is too much fuel will enter the carborator and cause flooding in the system to occur. Wait 20 minutes if this happens and start to crank again 5. Bad spark plugs are a major reason why many cars take a very long time to start 6. Please have your spark plugs removed and exchanged for new ones. Over time, spark plugs become fowled and prevent the car from starting even thou you hear cranking!!!
Jan 25, 2011 | 1996 Jeep Grand Cherokee
Starts runs until warm stops
I would replace the coil. and condenser.
Oct 18, 2009 | 1989 Jeep Cherokee
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Honda Pressure Washer PSI 3000 Logo
1,660 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
