Question about RCA D52W19 52" Rear Projection Television
D52W19 Regulator IC part number.
I want the regulator ic part number but can find it. Where is it located?
  • volcomschonk Jun 01, 2009
    I know its in this area.
  • Jim Krause May 11, 2010
    Which regulator and for which circuit?
  • 378 Answers
There are many regulator IC in TV you can find it easy the commonly used are 3 pin part number is 4 digit example LM7809/AN7809 this means possitive ic regulator 9v output. LM7909/AN7809 means neg. output 9V. so you can search it on your board. Good Luck
Posted on Jun 01, 2009
What is tcl 21e20 regulator ic number
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 30, 2014 | Televison & Video
Jvc av21wx14
It should be STR-G6653. A five solder terminal power regulator IC.
May 21, 2013 | Televison & Video
What is the parts number used in sony kv-21bmr1 ic regulator?
There are three IC regulators. Out of which ones number do you want? Circuit section? Position?
Jan 22, 2013 | Sony Televison & Video
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Regulator ic of sony tv kv-g21c1
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
Sep 01, 2008 | Televison & Video
Hernandez030763@yahoo.es
The flyback for JVC C-13910 is listed below. Do you have the location number for the IC Regulator?
JVC C-13910 Flyback T1522
Apr 22, 2008 | JVC C-13910 13" TV
About the Regulator ic
your welcome, just info me if you done to test the regulator ic.
Feb 22, 2008 | Acer AL1716 17" LCD Monitor
Floor model
If the IC your talking about has a designation number of IC601, the number is MX0841AB-F. Common regulator IC. Sony says that IC is no longer avaialable. You may get lucky and take out the entire G board and have ptscorp.com, or Tristate.com repair the board for you. Good Luck
Sep 17, 2007 | Sony KP-53S65 53" Rear Projection...
Screen menu displays locked & unlocked
Hold down the menu button for 5 seconds (with the monitor turned on). It should reset the lock option.
Mar 11, 2007 | SAMTRON 55V 15" CRT Monitor
RT2250 Shuts down on its own after a few minutes of regular operation.
I have the same problem and it seems like it is going into thermal shutdown as ICs 104 and 106 are overheating which are fed from C138. All input source voltages seem to be correct and I do not get any voltage fluctuation from any input on the following regulator ICs. IC 106 3.3 VDC regulator is giving me 3.3VDC as a Output Source voltage and IC 104 5VDC regulator is giving me 5.0 VDC. IC102 15VDC regulator is giving 15VDC output and IC103 -15VDC regulator is constantly dropping voltage from the time of "Power On" until shutdown which takes about 5-7 minutes. I get right around -11VDC when shutdown occurs. ICs 102 and 103 are not overheating which leads me to believe that the IC 103 -15VDC regulator is faulty and putting a load on the other regulators which are trying to compensate for the voltage drop. I plan to replace the regulator with an NTE 969 replacement.
Dec 19, 2006 | RCA RT2250 System
RCA D52W19 52" Rear Projection Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
