Question about Jandy Pool & Spa
Jandy 1.5 hp pump with jandy ae 2500 heat pump low flow
Experiencing sudden low flowproblem (worked first week) my hayward de filter reads as low as 5 psi i carefully cleaned , rinsed and reloaded the de to no effect. the hopper in the motor is nit completelyfiling with water nor is it ait bound
what could be causeing this decrease in pressure at the de filter since the advent of the a45oo???
  • 93 Answers
IF FILTER CUP IS NOT FILLING COMPLETLY THERE IS A AIR LEAK CHECK ALL HOSES AND FILTER FITTINGS
Posted on Jun 10, 2009
Low water return flow
sounds like DE remove grids clean then recharge with DE
Jun 14, 2012 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Hayward vari-flow valve sp714 cloudy water
Otherwise chemistry fine?
whenever someone is vague about chemistry residual readings, but provide a pH reading, I'm always Leary.
  • bring pH up to 7.6
  • Balance Total Alkalinity at 120 ppm
  • Bring Hardness to at least 200 ppm
  • Keep Chlorine level at least 3.0 All the time
  • ISO Cyaniric acid / stabilizer at least 30, not exceeding 80 ppm
  • Use a Natural Clarifier weekly - rate = 1 ozs per 5000 gallons
  • Use Algaecide (not from Kmart!) weekly
  • Clean filter whenever pressure approaches 8# over starting
  • Filter for at least 1 turnover per day. This is usually 8 hours in most regions
Follow this, should be good
May 25, 2012 | Hayward SAND FILTER, PRO SERIES
My pressure or psi has droped for some reason its a hayward new 1 hp pump about a year it should be running at about 10 psi I know when the psi rises I need to backwash as I have a had a pool now for about...
Some thoughts.
I have a Hayward pump. The other day my gauge jumped a gear inside and suddenly my pressure went up 5 psi from 15 to 20. After I backwashed, I saw it didn't drop and opened the gauge and saw the problem.
What kind of filter do you have? If you have one with filter cloth, like DE, a torn or damaged filter cloth could cause a drop in pressure.
Is filter flow better or worse than normal?
If flow is lower, there may be something stuck in the hoses, pump suction, impellar, pump discharge or discharge hoses or even filter valve.
These are some areas to check, pretty much in order of likelyhood.
Gary
Sep 10, 2011 | Pool & Spa
The pressure gauge on top of the filter only reads 5 psi. I backwashed and added DE and it still only reads 5 psi. It also read 5 psi after filter was backwashed and before DE was added. What prompted me...
Is there good water flow? Can you feel good flow at the pool return?
If so, using your hand, try to stop the flow. Does the pressure go up?
If the pressure goes up, something inside the filter is not presenting resistance to flow as is normal; it could be a broken element, etc.
If there is no flow or if the pressure doesn't go up, make sure that there is no obstruction in the line coming from the pool to the pump. Check the inlet basket, inlet strainer in the pump, look for debris in the pump inlet & pump outlet piping.
Gary
Aug 20, 2011 | Hayward 1.5 Hp Northstar High Performance...
I bought a used Hayward Perflex Extended Cycle DE Filter Model#EC45 I have to keep backwashing it, it flows heavily back in the return but it only flows good for a little while. What do I need to do? It...
Here is a link to the hayward manual. Be sure to follow the pre-coating insturctions carefully.
Use only the swimming pool grades of
diatomite, such as:
CELATOM . . . . . . . . . . . Eagle-Picher Industries, Inc.
AQUA-CEL . . . . . . . . . . Johns-Manville Products Corporation
DICALITE 4200 . . . . . . . Grefco, Inc.
WITCO . . . . . . . . . . . . . Witco Corporation
The EC-50 filter uses a 5 lb. (2.3 kgs.) charge of diatomite (D.E.)
Here is a link to the hayward manual for a EC-50 I think its almost the same as the EC-45
http://www.haywardnet.com/products/manuals/pdfs/manual10.pdf
Jul 01, 2010 | Hayward EC-40 DE Pool Filter with pump
My new ec50 is clogging frequently. Is at 18 psi
lower the better (psi) this means the water is flowing fast through the filter, high pressures means it's time to clean filter again. keep cleaning until the pool is squeaky clean, then you can go back to cleaning once a week
Jay the pool pump motor repair guy Longwood Florida
Jun 15, 2017 | Hayward EC50 SYSTEM W/ 1 HP MATRIX PUMP...
My hayward pool heater is displaying P5 and the fan is not moving. what does this mean?
You heat pump is actually displaying "PS" for Pressure Switch. Either there is not enough water flow or the switch could be bad. If you have a sand filter, put the filter head in the "bypass" mode and try again. If the heater works, filter problem. If not, heater problem. Instruction book found here: http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
Apr 08, 2010 | Hayward 116k HeatPro Heat Pump HP3100
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool heat pump problem.
It could be that there is a low pressure or low flow condition (water). Make sure the filter is clean and water level in pool is proper. Also the temp sensor may be failing.
Apr 19, 2009 | Jandy Pool & Spa
Pool & Spa Logo
327 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
