Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Refrigerator warm, freezer is fine.
The refrigerator has quit cooling, however, the freezer is working just fine. When I put my hand under the "vent" I can't feel any cold air. When I open the freezer door and put my hand under the "vent", I can feel cold air going into the refrigerator. Damper? Fan? hotpoint top freezer, works fine. refrigerator not cooling, only 2 and l/2 years old, not abused. i am just upset about this, $75 to come out and check and told these refrigerators only last about 5 years. should i buy a new and better one. thanks i am in a townhouse, not sure of the size Vickie thank you
  • 232 Answers
This could also be a plugged defrost drain ice building up blocking air flow through the return vents is therehwater dripping into frige
Posted on Jul 01, 2009
    Novelist:
  • 103 Answers
Hi: It is either the defrost heater (most likely) or the defrost timer. The airway to the fresh food is clogged with frost. I doubt your freezer is packed as you could put your hand on the vent. If you block the vents this can cause the problem also. Check the defrost heater and replace if necessary. It is a wire coil in a glass tube. if the coil is broken it is bad. Look at your parts list or on line at Sears Parts. to find out where it is. I hope this helps, Jeff
Posted on Jun 01, 2009
Side of freezer felt very hot, the fridge and freezer were working fine, but the sides were definitely too warm. When taking off the back paneI and watching for a while, I noticed that the fan to cool the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
GE Profile TFX22PR side by side. Freezer works fine, but Refridge side is not holding cold temp and the door gasket is quite warm to the touch.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 02, 2010 | Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Jenn Air JCD2389GTW Refrigerator problem
The auto defrost timer was broken, so my refrigerator repairman replaced it. The part is about $60. The bigger expense was the labor getting to the timer, which is in the upper right hand corner of the refrigerator within the plastic casing that houses the temperature control levers. He then had to remove the panels of the freezer and defrost the coils with a blow heater. It took several hours.
Feb 28, 2008 | Jenn-Air JCD2389G Side by Side...
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
334 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
