Question about Biostar U8668D (802700113338) Motherboard
Boot problem i installed windows xp on my U8668U-D motherboard and when it reboots it wont go into O/S i dont understand all it does is go into the boot options ie- safemode, safemode with command prompt, last known configuration that worked and start windows normally ,,, last known works but any saved info or newly added programs are not there,,,, hopefully its an easy fix thanks for any info
    President:
  • 2,351 Answers
Since this is a fresh install of windows, suggest you download the manufactures hard disk drive floppy disk setup software. Each manufacture has their own bootable setup software that works in a DOS like window. You'll be able to check the drive, set the drives
FAT = File Allocation Table. Check the drive for errors & format the drive just to name a few things.
Once completed remove the bootable floppy disk/CD.
Insert your windows CD & reboot your system. Install windows again. (Do not use windows to format your drive. (You'll have already done that with the manufacture's software disk/CD).
Example, here is the link for Seagate IDE drive's;
http://www.seagate.com/www/en-us/support/downloads/seatools
Here is the link for Maxtor drives;
http://www.seagate.com/www/en-us/support/downloads/maxtor_desktop/
Western Digital drive's;
http://support.wdc.com/product/download.asp?wdc_lang=en
Samsung hard disk drive's;
http://www.samsung.com/global/business/hdd/support/utilities/Support_DiskManager.html
My bet is there is something not right with the drive. Using the manfacture disk software will correct just about any problem that may be hindering data to be written to the drive.
Mike
Posted on Jun 01, 2009
How to install window xp
Hi, you will need to set up your hard drive first. During initial boot fase press the F8 key which will take you to the BIOS. Select boot device and change primary boot device to CD Rom. Insert XP Cd into drive, select save changes and reboot. Select boot from CD when this appears by pressing any key. Allow files to install, when this completes you will need to delete any previous operating system, partition hard drive and then format hard drive. Once this sompletes reboot, ignoring boot from CD this time and XP will start to install.
Aug 25, 2010 | Intel Motherboard
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Brian
Jul 09, 2009 | Intel Computers & Internet
I CANNOT INSTALL WINDOWS XP PRO
u need xp bootable cd then u can directy boot from cd & istall windows xp here is the link for u
windows xp download
Jan 25, 2009 | ASUS P4S800D-X Motherboard
System wont boot
i would slave the drive into another system revmove the data off it that i want to keep and then repartishion the drive and do a fresh install.
regards, daniel
Jan 12, 2009 | Abit IC7-G Motherboard
I have a video problem
its been a bad install of the drivers, boot into safe mode and uninstall the display drivers, reboot the machine and it should reinstall the drivers itself
regards
Nov 26, 2008 | Sony (A8045060A) Motherboard
My computer was not boot the file
Greetings!
Your problem is your computer do not boot, just insert the cd installer of windows xp, an option will come in to repair your system file, select the repair. If that will not repair your computer you have to re-install the windows xp.
Thanks.
Nov 12, 2008 | Intel Motherboard
Reboots every 30 seconds or so
Check all your fans and heat sinks including power supply one
Also check CPU heat sink for fluff and dirt
Sep 09, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Problem with replacing the motherboard and keeping my old hard drive
Windows XP questions and answers CH000635, How to get into Windows XP recovery console without a Windows XP CD. CH000646, NTOSKRNL.EXE is missing or corrupt.
How to create a boot disk. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
How to erase my hard disk drive and start over. If you are running or plan on installing Microsoft Windows XP please see ... First, we recommend that all users wanting to simply install Windows NT use the .
How to use the Windows recovery console. Place the Windows CD in your computer and boot from the CD. ... To repair a Windows XP installation using recovery console, press R.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | ASUS P5RD1-VM Motherboard
MS-6787
install raid drivers only if you are certain that you are on RAID and even before you install raid drivers make sure the RAID controller is set to on in BIOS. if you dont have RAID setup then please dont install the RAID drivers. the only reason i think you are computer is not going past the windows xp logo is you might have floppy drive in the boot sequence(in the BIOS screen) set to on or you must be having a USB device connected to the computer. set it to "no boot" and things should be fine.
Jul 04, 2007 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Biostar U8668D (802700113338) Motherboard Logo
211 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
