Toa PA amp TA266 with open circuit transistor marked 536F9. I think this number is a part number and not a transistor number. Can you help with an equivalent transistor, Thank you, Doug Cooke
  • 2 more comments
  • stanley386 Jun 01, 2009
    Dear Sir, There is no way in the world that you can come up with a solution this quick.Your answer is basic component teaching and has nothing to do with the problem. Please read the question, you have obviously sent me an auto generated computer answer or from someone sitting at a computer that hasn't got a clue. At least forward my query to a technician as I am sure that you can do a lot better than this, thank you.
    Many thanks for your prompt reply and interest, there are two boards in the amp, this transistor is in the first one which looks like a signal or pre amp and the second is a power amp. This a pretty old amp and numbers hard to read,the board number is 101408012 or 101468012. The 536F9 is the only number on the transistor. Circuits are probably non existent but if you can find something in the old 30watt TOA range it may do the job. Your time much appreciated, Doug.
  • stanley386 Jun 02, 2009
    Once again you have not addressed the problem, I have my doubts if anyone at Fixya has even read the query. Seems to me you are just computer generating answers, avoiding the issue and sending me irrelavent answers. If you do not have knowledgable staff and cannot help please say so. Please no more mindless compuer generated solutions, ask a technician!
  • stanley386 Jun 03, 2009
    If I knew the manufacturer of the transistor I wouldn't have a problem! Can you source a circuit for a TA266 Toa amp and have a look in the pre amp section. There are only 5 trannies in there, two have proper transistor numbers and three have these part numbers. Support from Toa would be the way to go but I don't know how to get on to them, especially in this neck of the woods. Thanks for your help.
    President:
  • 1,734 Answers
Hi, the 536F9 was a branded part of CMB Components. I still have the following US telephone numbers:
OEM Division Tel:(631)244-2700 Fax:(631)244-2745 | Broker Division Tel:(631)244-9800 Fax:(631)244-9811
You could order it here, but there is a minimum $ order.
Here is a datasheet of an possibly equivalent part from FILTRAN:
http://pdf1.alldatasheet.com/datasheet-pdf/view/169460/FILTRAN/1536F.html
Hope that helped.
Posted on Jun 03, 2009
    President:
  • 1,865 Answers
I need to know the manufacturer of the transitor so that I can find an equivalent
Posted on Jun 02, 2009
    Brigadier General:
  • 3,614 Answers
Transistors can be identified by a Joint Army-Navy (JAN) designation printed directly on the case of the transistor. The marking scheme explained earlier for diodes is also used for transistor identification. The first number indicates the number of junctions. The letter "N" following the first number tells us that the component is a semiconductor. And, the 2- or 3-digit number following the N is the manufacturer's identification number. If the last number is followed by a letter, it indicates a later, improved version of the device. For example, a semiconductor designated as type 2N130A signifies a three-element transistor of semiconductor material that is an improved version of type 130:
As you are the one who can see the circuit, try to read and determine what exact # of the transistor
Let me know
Posted on Jun 01, 2009
  • 1 more comment
  • micromaster
    micromaster Jun 01, 2009
    can you please send me out the exact part# of the mainboard. i was instructing you to feed me in general the number or what you can see that labeled the transistor you were gonna replace. well i am here and you are there, i cannot actually determined which transistor your referring.
  • micromaster
    here is the example part# and description for each resistor. can you identify which it is?
  • micromaster
    also try to look at this one HERE
    Update me again
Power light is lit, but there is no sound coming from the speakers , it was working fine and just stopped working ?
Its an PA amplifier and i think this is build with an integrated powerpack IC output stage,
There are different TOA amps but if this model look first the fuses if that are (important)measured defect give a new fuse a try if it blows again there is something wrong in the cables or a speaker conection or filter , ut if the fuses are good there could be an single great brown or black colored IC with STK (....)A or B or something similar is to read on it on the great heatsink inside the amplifier that could be having 15 or more legs must be replaced , BUT also some capacitors thats belong to the output stage because every defect is having a cause.
It think this amplifier IC should similar be looking like this
Aug 05, 2016 | TOA Electronics - P-924MK2 - 240 Watt...
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Mar 18, 2014 | Radio Shack Audio Players & Recorders
My toa a-912mk2 amp does not work and the red protect light stays on
• Check for shorted power transistors, and extract in pairs.
If it powers up, without protect..
• Check again for possible additional components before replacing
the bad ones.
A good amp never produce an over of 0.7V on its output.
Sep 06, 2012 | TOA Electronics A912MK2 Amplifier
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
I have a TOA 301 15W amp and a Bose 151 environmental speaker(40w 4 ohms). I do not have a manual for the amp and wish to connect the speaker as a small PA . My concern is that the output I think I should...
Don't worry about the 7.7 volts. Just connect between COM and 4 ohms and you'll be fine. I didn't find a 301 part number related to a 15w amplifier, but I did find a BG series (115 130) of 15 watt amps manual http://www.toa-products.com/international/download/manual/bg115_mt1e.pdf
Carl
May 08, 2011 | TOA Electronics Audio Players & Recorders
Blown fuse everytime it powers on
yes right there is a short circuit in power supply if you are non technical then replace the power supply if you are technical then open the power supply and check the 4diodes of bridge if faulty replace it again check transistor attatched to heat sink if faulty repalce it
Feb 28, 2010 | Pyramid (PS36KX) 600-Watt Power Supply
I have an audiobahn A8000t amp with the protection light on
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Speakercraft bb50 power amp
Can you post the markings on the existing transistors? Also, if these are the output transistors, there shouldbe a complimentary one located close by Q24+Q34 maybe? Post those markings too.
Thanks,
Dan
Sep 28, 2008 | Audio Players & Recorders
260 people viewed this question
 Grubhead
Grubhead
