Question about Kenmore Washing Machines
Kenmore washing machine will not fill with water.
Sometimes our Kenmore washer will not fill with water, the water for some reason leaks out as fast as it pours in. It will then run for hours because it won't start the next wash or rinse cycle until it is filled.How do I fix this?
  • elevaguy Jun 01, 2009
    The drain hose comes out of the bottom of the washer and goes up at least 3 feet before going into the wall, so that is not the problem. Do you have any other ideas?
  • 6,784 Answers
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on Jun 01, 2009
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
It turns on and fills by itself. sometimes it
a bad water valve could cause this / if it leaking through . when the tub is full it will start itself and cycle . / also the control if bad would do this .. mm
Dec 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Water leaking when washer is filling
  • Is the water coming from the front center?
  • if it is it is coming from the water pump.
  • just let me know which side and how fast it is flowing
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
