My paper shredder stopped working
My shredder stopped working in the middle of shedding a piece of paper. The motor is running but the blades won't turn. What could be the problem?
    Scholar:
  • 41 Answers
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Posted on Jun 01, 2009
Why won't shredder turn off automatically?
turn off and unplug; then turn over to see if there is any paper jammed in the shredder. MAKE SURE YOU TURN OFF AND UNPLUG BEFORE YOU WORK ON IT.
Clean out any jammed paper or plastic with a bamboo skewer or something like that. DO NOT put YOUR HANDS near the blades.
Jul 15, 2014 | Destroyit 2603 SMC Shredder
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Jan 25, 2014 | Intimus 280 Shredder
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    The shredder has stopped working for either CDs or paper. The green light comes on when the switch is set "auto", but it won't shred
    Is it Jammed.??? does the motor at least run.????
    If the motor runs but the cutting blades dont turn then youv'e lost a gear inside....if the motor dosn't turn at all...then youv'e prbably lost the PCB inside...also make sure youv'e cleaned the Glass eyes in the middle of the paper oening....for parts give Royal a call at 1-800-524-0799.
    Aug 30, 2010 | Royal VF1000MX Shredder
    My paper shredder wont turn off
    Shredders have sensors that tell it to turn on. Usually the there is a spring loaded button/sensor in the middle of the slot that you feed the paper in. Once the sensor button is pushed down, it thinks a piece of paper is being fed in and begins to turn the blades.
    If your shredder won't stop running, I think the sensor button is stuck in the down position.
    1) try pushing the reverse button for a while to see if it clears the problem.
    2) if not, then unplug the shredder. Find the button/sensor near the middle of the shredder slot and with a tweezer, try removing any clogged scraps of paper near the sensor button to get it to pop up fully.
    3) I've never seen a shredder with more than one sensor in the middle but if yours has more, make sure they are all in the popped up position when there is no paper in the shredder.
    4) Plug the shredder back into the AC outlet and try it again. Good luck
    Aug 08, 2010 | Office Equipment & Supplies
    My shredder quit working.
    First thing you have to do is clear all jammed paper. Second..try running machine; if the motor runs and the blades turn put some shredder oil into the cutting blades as lubricant. If the motor wont run you have probably blown the pcb because of too much paper... to get replacement part call Royal at 1-800-524-0799.
    Jul 15, 2010 | Royal Office Equipment & Supplies
    Royal 85x crosscut shredder stopped working
    Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
    If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
    May 25, 2010 | Royal 85X Shredder
    It will not grab the paper; need to press forwared
    May 24, 2010 | Quartet gbc Shredmaster 6550X...
    CHAMPION PAPER SHREDDER
    My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
    Oct 20, 2008 | Office Equipment & Supplies
    Paper Shredder blades do not turn, even though motor is running
    yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
    Jun 08, 2008 | Office Equipment & Supplies
    889 people viewed this question
    k24674
    jasbo
    jasbo
