Question about NEC Electra Elite 32D-1 Corded Phone
NEC DTU-8D-1A TELEPHONE
PLEASE ADVISE HOW TO SWITCH THE HANDSFREE MICROPHONE ON. THERE IS NO "MUTE" KEY ON THIS MODEL BUT THE HANDSFREE MIC WORKED PERFECTLY WELL UNTIL A COUPLE OF DAYS AGO. THERE IS A SMALL RED LED IN THE BOTTOM RIGHT CORNER THAT INDICATES THAT THE MIC IS ON AND THIS SEEMS TO DEFAULT TO THE OFF POSITON WHEN THE PHONE IS UNPLUGGED. AS YOU MAY HAVE GUESSED THERE IS NO USER MANUAL IN THE OFFICE!!
  • Anonymous Aug 19, 2008
    Hello I did the # Feature 1 and my headset is still not working. Is there something eles I can try?
Press Feature 1 That will turn the mic off, or on.
Posted on Aug 19, 2008
How can i enable the head set jack on our dtu-8d?
Posted on Jan 28, 2008
  • brightone Jan 28, 2008
    Press # feature 1in that order
SOURCE:
How do i stop flashing feature light on my nec dtp-8d-1a
Try rebooting your phone system. That helped with our system.
Jun 20, 2014 | NEC DTU 8D-2 Corded Phone
How do I turn off the blinking lights on my DTU-8D-2(BK) Telephone
Unplug the line cord. While holding down the * and # keys, plug the line cord back in. Release the * and # keys.
Follow the directions on-screen, which will test all display modes, buttons, and sounds for both red and green colored LEDs.
If the feature button continues to flash, press it and then lift the handset and hang up.
Sep 09, 2011 | NEC DTU 8D-2 Corded Phone
HOW DO YOU PLACE THE PHONE ON MUTE?
Feature - 1. The light will go out above the MIC text indicating that the microphone is turned off.
Aug 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
How do you change the time on a nec phones dth-8d-1(bk)tel
To Update Time: From operator telephone with receiver hung up; Press feature key; dial 9,#; enter hour and minute i.e. 0135; (press recall key to change from am to pm); press feature key to save and exit.
Mar 26, 2009 | NEC DTU 8D-2 Corded Phone
Why is the mic "lit" on my NEC Elite 8-Button Display Telephone DTU-8D
when the light is lit it allows hansdfree use of your phone.
Jan 31, 2009 | NEC DTU 8D-2 Corded Phone
Mic ltie
If it used to work, and now suddenly it doesn't, likely the condenser microphone inside the phone is bad or has built up a static charge. If it used to work and you now here a buzz or humming sound instead of voice, you will need to discharge the microphone by disassembling the phone and shorting the two wires that go to the microphone (with the telephone unplugged!). I'm assuming you are referring to intercom calls and therefore the programming for handsfree outside line calls (memory block 4-29) doesn't have any bearing. If it used to work and the above procedure doesn't fix it, the phone is probably bad.
Jan 19, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Mic not working
You need to press feature than the number 1 to turn on your mic. You can find support and get anything you may need from ldtsnj.com
Nov 19, 2008 | NEC DTU 8D-2 Corded Phone
NEC Telephone speakerphone. You can hear the caller, but they can't hear you.
Chance's are it's a bad hand set, Swap with another to see if problem follows it. if it dose, replace it.
Richard
Oct 01, 2008 | NEC DTU 8D-2 Corded Phone
Difficulty reading screen
As an FYI....The arrow keys control many things,
If not in use, they control the contrast.
If ringing, it adjusts ringing.
when using handset or speaker, it adjusts volume.
Jan 17, 2008 | NEC Electra Elite 32D-1 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
1,510 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
