Question about Electrolux EIDW6305GB 24 in. Built-in Dishwasher
Water not draining out all the way. Standing inside bottom of washer, about 1" deep. Is this normal?
  • hement Jun 02, 2009
    the line was kinked, I cut off the bad section and reinstalled the hose. I am running a cycle right now and it sounds better already. Thanks for the input. It is much appreciated!
    Brigadier General:
  • 8,619 Answers
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 01, 2009
Standing water in dishwasher
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
Mar 11, 2015 | Frigidaire Dishwashers
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Water will not drain in whirlpool dishwasher
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 20, 2009 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't finish cycle, water still in tub, code nd
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Oct 03, 2008 | Miele Novotronic Premier 500 Front Load...
Bosch WFK2401 Drain Pump
I have a WFL 2060 UC on the bottom right there is a small access door. Inside the door you will find a drain plug which will unscrew counter clock wise. Water will come out so I tipped up the machine and slid a 1" deep cooking pan under the corner. When I unscrewed the plug I found a penny inside.
Aug 24, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Electrolux EIDW6305GB 24 in. Built-in Dishwasher Logo
702 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
