SOURCE: Have replaced Lamp and still does same thing.
I replaced the ballast, a solution not even mentioned by the 3 Experts I was referred to.
SOURCE: Have the 6165wx tv won't turn on flashes 3 lights
The tv's lamps life span is about 3,000 hours of viewing pleasure. Some lamps exceeds and some barely reached the 3,000 mark, but when this happened you will not have any pictures showing, but it have sounds. This means that lamp is already burnt out and needs to be replaced.
SOURCE: samsung hls4266wx/xaa tv. tv
I put a lamp in to my Samsung HLS4266WX/XAA, but when I actually took it apart for the Bulb replacement which I have done twice now. I found where that switch is, that gets pressed when you have the back cover to the bulb screwed in was hanging, and I can get the new bulb and my replacement bulb to work for about 15 secs, and at one point it was working really good. Can anyone help me with this problem, cause Im getting frustrated. It seems like a simple fix,but its almost like the bulb I ordered is not as good as my other replacement bulb.Its from MWAVE.com, anyone heard anything about this company? Please help if you can, id really appreciate it.
Joe Red
SOURCE: no picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
