Question about Bernina Sewing Machines
Starting overlocking Have threaded the machine (bernina 1300 mdc) as per instruction book and everything looks correct but the stitch won't lock. How do I get the overlocking thread started?
    Brigadier General:
  • 3,614 Answers
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Posted on Jun 01, 2009
  • Bernina Master
  • 12,487 Answers
The 1150 is similar to your model. This manual might be of help:
BERNINA Support Machine and Accessories Finders and Software Support...
Posted on Jun 08, 2015
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I get the correct tension on my Elna 792D 4 thread overlocker?
ALWAYS Raise the presser foot when threading the machine. Give each thread and extra little tug when threading the tension disks so it seats completely. The midway point on the tension disk is the standard factory setting when using the standard thread weight, however, with use, age, and thread weight that setting may change. So, the user can use the midway point as a starting point for the basic overlock stitch but will need to make adjustments to get the correct tension. When testing your tension, it works best to use the 4 thread colors so it is easier to identify which thread is misbehaving. When you become familiar with your machine and how the stitch looks, it is easier to identify which thread is which.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
Solving Serger Dilemmas
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwjjhv6Uw4PSAhXJrVQKHQrmCtgQFghBMAY&url=https%3A%2F%2Fwww.bernina.com%2Fen-NZ%2FExperience-NZ%2FSewing%2FSerger-projects%2FUSA-nz%2FSewing-Embroidery-nz%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-nz.pdf&usg=AFQjCNEAPID5FKBVa_amKfVmrTKgadlmRw&cad=rja
Remember that the tension settings will also determine the stitch you are trying to create. A basic overlock will generally have the tension set around the midway point, however, when changing to a rolled edge or some other stitch, certain tensions will be increased or decreased in order to create that particular stitch.
Feb 09, 2017 | Elna Sewing Machines
Although overlocker is correctly threaded it does not form a chain
here's a link for a manual
http://www.sewingpartsonline.com/instruction-book-elna-t33.aspx
try changing the needles & see if that helps the machine to form
a proper stitch, if it doens't then it's possible that the machine
could be out of time & needs to be checked at a sewing machine
shop
Aug 20, 2012 | Sewing Machines
What should I pay for a Bernina 1300dc. It has been used once and stored in a box for years. All parts, manual are included.
Take a look on amazon for Bernina sewing machines... You can find there various prices (100% cheapest on the net). Here: . Amazon com bernina sewing machines. I hope this was helpful. Cheers
Sep 21, 2011 | Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
342 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
