Question about Dell XPS M1330 Notebook
Can't burn a CD with my Matshita drive, what do I do?
I cannot burn CDs on my laptop. I'm using a Dell XPS with Windows Vista, my drive is Matshita and won't accept anything. Please help me!
  • ultimitloozr May 11, 2010
    Can you read CDs (both autio and data)? What error messages are you receiving? Is there anything in the Event Logs regarding the problem with the drive? Are there any errors reported on the Properties page for the drive in Device Manager?
  • 197 Answers
Have you tried different cds? If yes but persist try re-installing your burning software. If it still doesn't work I suspected your dvd rom drive is faulty. You might need to change it.
Note: no need to pay for a replacement if machine is under warranty.
Posted on Jun 02, 2009
  • iya velasco
    iya velasco Jun 02, 2009
ASUS M51SN Matshita BD UJ-120 burner does not work - Windows 7
You need to install windows 7 (32 bit) not 64. To change to 64 you have to make internal changes and updates to your notebook. Your notebook is set up for 32 bit systems.
May 19, 2010 | ASUS M51Sn-C1 Notebook
this will be an isue with the drivers for the drive you will have to get the windows 7 drivers
My Matshita dvd ram uj 857s says code 10. I have
It's not "regeit" but "regedit".
Drives Disappear After You Install ITunes or Norton Ghost** If after installing ITunes or Norton Ghost, you get Device Manager error code, try locating the Audio File System (AFS) driver from Oak Technologies at C:\Windows\System32\Drivers\afs.sys or doing a search for it. Rename it afs.sys.txt and reboot. This driver is incompatible with the driver found in iTunes and Norton Ghost. The driver from these two companies is the same and made by a third company called Gear Software. After renaming the afs.sys driver file you will lose access to the CD burning feature of of the following: HP Memories Disc Creator, Liquid Audio Portal Player, Oak Technology SimpliCD, or Broderbund's Print Shop version 20. If you still wish to use the burning feature in any of that software, upgrade it to a Vista versions. For more information, see the article here - http://www.gearsoftware.com/wiki/index.php?title=CD/DVD_drives_disappear_after_installing_iTunes.
Description of Code 10-related errors that Device Manager generates in Windows-based computers
http://support.microsoft.com/kb/943104/
Please do all the below even if you have done some before as it is often the total process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
Then work your way through these - remember the drive could be bad, could have a loose cable or
slight corrosion on the contacts (usually for a laptop) and other issues.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Dec 30, 2009 | Dell XPS M1330 Notebook
HELP FIX MY CD BURNER
How are you burning cd's which software program. Is this though windows, or alternate software. Also are you able to read cd's through my computer.
Nov 30, 2009 | Dell Computers & Internet
Matshita dvd drive UJ-85JS issue
clean the lens of your dvd player, it may solve your problem, otherwise replacement of drive is the best solution.
Sep 15, 2009 | Panasonic Matshita- | CW-8124-B | USB 2.0...
DVD burner doesn't reconize burned music cd's only shows them as blank disc
Have you tried to play burned music disc with other laptop? if it was able to play there then i suspected your dvd-rom drive is faulty.
To confirm, try playing different cds from your machine and check if it was able to read it.
Jun 03, 2009 | Dell XPS M1330 Notebook
My matshita uj-860s disc drive has stopped working
In my case, MATSHITA DVD-RAM UJ-860S did not want to write CD-R,-RW Verbatim using software NERO 8, but is easy to write their own software windows XP.
in the Log file was as follows:
Could not perform start of Disc-at-once
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Power calibration error
whether
Invalid field in parameter
E: MATSHITA DVD-RAM UJ-860S
ACTION! :)
Change in method of recording NERO 8 Burning mode: DAO (Disc-at-once) at Burning mode: TAO (Track-At-Once) all have established!
Simply drive MATSHITA was UNSUPPORTED software producers to write disks.
Updating the software to burn CDs, as is windows XP supports the recording and includes drivers for the drive! :)
Apr 17, 2008 | Computers & Internet
Dell XPS M1330 Notebook Logo
527 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
