Question about Electrolux EIDW6305GB 24 in. Built-in Dishwasher
There is water standing in the bottom makes dishes smell musty when drying
Water standing at the bottom
    Scholar:
  • 66 Answers
There should be some sort of filter at the bottom of the machine, try popping that off and cleaning it off manually, also make sure after you take off the filter plastic that the hole under it is not clogged. if it is a must CAREFULLY run a coat hanger into the hole to clear any obstructions.
Posted on Jun 01, 2009
We just purchase home weeks ago.I opened the bosce dish washer found it had a musty order.The following day i ran a dish washer agent,which didn't work.clean the washers filter noticed green algee.
Put two cups of bleach in it and run it on a long and hot wash. The best way to stop the odor is to use it regularly and leave the door open for 15 minutes after you use it so it can dry out a bit. There will always be some water in the bottom in the pump.
Sep 23, 2017 | Cars & Trucks
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
There's a bad smell coming from my Amcor AF9000E NanMax portable AC unit. It smells like the smell that you would find in a damp, musty basement. Is there anything that I can do to illuminate this...
Yes there is. First turn the unit OFF & unplug it. The remove the air intake filter and clean it. After that, remove the water collection bucket and was it in warm water and mild dish washing liquid. Rinse and thoroughly dry. Doing this should help to eliminate the odor.
Thanks for choosing FixYa.
Jul 29, 2011 | Amcor AF9000E Portable Air Conditioner
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Musty smell coming from machine
Small hidden water leaks will cause a musty smell. Usually the leak is from a dried out hose
May 12, 2010 | Washing Machines
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water seems to be left in bottom of washer
This is a Maytagism for this style of washer.
Quick solution... take a terry towel and wipe out the standing water in the front door seal area and when you're done, toss the towel into the wash load.
Also make the loads a little smaller...it will keep the smell from reoccuring as much.
Jun 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smell in LG LDF8812ST
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door ajar...do not close tightly.
Nov 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
Electrolux EIDW6305GB 24 in. Built-in Dishwasher Logo
296 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
