Question about Xerox WorkCentre M20i All-In-One Laser Printer
Lamp will not go all the way across the window to copy. Just comes out a few inches then goes back and turns off!
    President:
  • 2,072 Answers
I would suspect that the shipping latch is causing the problem.
Look in the area where the paper comes out. Look up and on the bottom of the scanner, there is a green latch, about 2 inches ling and a half inch wide.
Push it in to the inside of the machine first then pull it out toward ou until you feel it snap into place.
I do believe that will resolve your problem.
Let me know. We will start with that.
Posted on Jun 01, 2009
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony Televison & Video
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Copy lamp Does not come on
Do you get a error code? I would say if the lamp is not turning ON it needs to be replaced or the thermal fuse is blown. Ceck for inpedence acrossed the two
Jul 02, 2009 | Sharp AR-5320 Black and White Copier
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
60 inch wide screen sony lcd
Symptom shows its Lamp Replacement time in KDF-E60A20 TV
If you have not replaced TV Lamp yet then change it.
Lamp is available in Part Store and lamp procedure is written in User Manual.
Mar 27, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
I have a WorkCentre XK35c/25c that I now use just as a copier.(Not hooked up to computer) When turned on it has power but when you hit start it sounds like it is going to copy as the light bar goes across...
The scanner for the flatbed has failed to properly move. The rails may be dirty, or the motor may be binding. Additionally there is a home sensor switch that must be activated when the scanner is initialized. Finally, when the copy button is pressed, does the lamp on the scanner come on within a few seconds?
If not, the scanner lamp may have failed.
Zenbob
Jul 28, 2008 | Xerox Office Equipment & Supplies
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
