Question about Canon PowerShot A460 Digital Camera
Day Light Pictures looks over exposed
Dear Sir. I have the above camera which I brought from Dubai 2 years ago. I have a problem now. When pictures are taken in day light, it looks like over exposed. Why is this..?? whenever i use the camera during daytime it will not take picture its white screen, why?????
  • j_minasalvas Jun 01, 2009
    i will try these...i dont know if there is high and low for exposure.. i will try to check
  • pickmynose May 11, 2010
    Does your camera have exposure options?
    The exposure could be set too low(or high) which might be allowing too much light to be captured in your canon.
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
For your camera (the A460) it's not possible to set the shutter to 15 seconds. Instead, set it to manual mode, turn off the flash, go to a darkened room, take the picture and open the door while the red and yellow light are flashing. Repeat until the shutter becomes unstuck. However, I must say that the chances are probably not very good to fix this with this method. And unfortunately professional repair will be too costly. If repeated tries do not work, it might be time to consider a new camera.
Posted on Jun 01, 2009
  • CameraR
    CameraR Jun 02, 2009
    Try setting it to full automatic first. Rotate the selector dial to the first little red camera icon next to the blue arrow. If the selector dial was in any other position than this, then this may have been your problem to start with.
This is to inform that I am having Casio Digital Camera Exilim EX-Z500 for last few years. The same was giving very good pictures, but last week, it suddenly started malfunctioning. Whenever, we took...
Some things to try: 1. Go into the menu and find "reset" to return to factory default settings. 2. Check the ISO setting....you may have it set too high for outdoor pictures. 3. Check the "exposure compensation"...it should be at "0".
Oct 12, 2010 | Casio Exilim EX-S500 Digital Camera
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 23, 2009 | Canon PowerShot A460 Digital Camera
LCD screen is very dark, Pictures taken are underexposed
If the pictures show up normal on the computer then the back light for the LCD is going bad.
Apr 05, 2009 | Canon PowerShot A640 Digital Camera
Pictures Becomes white (Excess Exposer or ISO)
I'm not clear about your last sentence. It sounds like you may have accidentally set the camera to use exposure compensation to over-expose the images. To reset this, see page 27 in your user manual. If you don't have the user manual you can download it here from Kodak. If you said in your last sentence that this is not the case, I apologize for not understanding you clearly.
If this is not the case, then the light meter in the camera may be malfunctioning, telling the camera that it doesn't have enough light.
1) Make sure the light sensor is clean. This is the lower of the 2 small light buttons on the front of the camera, to the left of the lens as you face the camera. If that doesn't help try:
2) Use a - setting in Exposure Compensation to under expose the images to compensate for the damaged light meter.
If neither of these help, then it needs to be sent in for repair, or replaced. (If the camera is out of warranty it is likely that the repair cost will exceed the value of the camera and you should simply buy a new camera.)
jc
Dec 28, 2008 | Kodak EasyShare DX4530 Digital Camera
Dark Pictures
Hello Cowgirl, It sounds like the camera settings have been changed in the menu.Check to see if all control items are set to "AUTO"
This should take care of problem.The camera did not go bad not being used.
Best Regards, Russell
Dec 19, 2008 | Kodak EasyShare DX6490 Digital Camera
Pictures have brown instead of color look, why
You have a bad film pack. Replacing the film pack with a new one should fix the problem. Nothing in the camera can change the color of a picture. The camera can over expose pictures (wash out the picture), under expose pictures (dark pictures), or the picture can be out of focus (blurry).
Nov 16, 2008 | Polaroid One600 Pro Instant Camera
My Canon PowerShot A80 has a metering problem I think
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck.
Nov 06, 2008 | Canon PowerShot A80 Digital Camera
Over exposure
Hey - have the same problem. All my still pictures are coming out overexposed, no matter what setting I use. Tried resetting, tried new battery, tried new memory card, tried different exposure settings. Nothing fixed it or affected it. However, my movie exposure works great so I can take movies just fine. Are you able to take movies with no overexposure?
Jul 25, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
My pictures are all coming out looking exposed
it sound like your film canister is letting in some light and exposing it and or there is an issue with the lens it may not be focusing right and may be leeting in too much light good luck getting this resolve i wish you the best of luck
Oct 12, 2007 | Minolta Maxxum STsi QD 35mm SLR Camera
Canon PowerShot A460 Digital Camera Logo
419 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
