Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
No chlorine reading
Yes I just got a new intex saltwater system yesterday and hooked it up and set it for 12 hours and this morning when I went to check the chlorine it showed no chlorine how long shoul it take to chlorinate a intex 24 x24 pool? I have had the water tested and everything else in the pool is balanced and ready to go except it shows no chlorine? Got generator running and no chlorine, right amount of salt is added. Do I have to run it longer, I have had it running the recommended time but still shows, low on chlorine. The generator is working but not sure if generating chlorine.
  • colingreenin Jun 01, 2009
    still got the problem that the water if yellowish and my wife and I think, and are sure it is because of the low clorine level
  • Anonymous Mar 19, 2014
    low flow light is on and i have cleanedthe calcium build up yesterday andgot everythign going then today same tyhing. currently got it soaking overnight any other ideas
    President:
  • 272 Answers
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Posted on Jun 01, 2009
  • rjbeg123 Jun 01, 2009
    Well Intex is open today give them a call, obviously you don't believe me.
  • jujukykysmim
    jujukykysmim Jun 22, 2012
    my pool test strips show no chlorine I have had the inrwx xaltwater set up for about three weeks the strips have never showed free chlorine and my water has either been cloudy blu and when swimmers are in it it turns green or its just green. I shocked and bought some type of algie stuff that the pool store recommended but I still cant get water right. I have an intex 16 x 48 above ground with an intex salt water pump hookes up to my original pump. I have tried the boost cycle, adding more salt . and I justcant seem to get nivce clear see thru water any suggeations I am ready to throe my hands in the air
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
I have set up the intex saltwater system. We have run the salt generator for several hours, however the chlorine reads 0. I have added conditioner (thinking this was the issue), however, everything else...
The short answer is add some chlorine. Clean your cell and assure it is operating normally per you owner instruction. Normally, the manufacturer recommends physical cleaning followed by acid wash. Of course use the usual safety precautions when using muratic acid.
Conditioner? Is that Cyanuric Acid? or is this a sequestering agent for removing metal?
Thanks for your interest in FixYa.com
Jul 03, 2011 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
88 flashes on display screen
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Jul 03, 2009 | Intex Automatic Salt Water System for ...
NO CHLORINE
i just went through this
Are you using the instructions in the manual for locking the system after setting the number of hours?
If you are, they are not right
unlock the system, set your hours then press and hold the down arrow until it beeps and then press and hold the up arrow until it beeps, the system is now locked and in about 10 minutes the chlorine light will come on. Our pool went green and now that we have it running right the colour is changing before our eyes. Changed the filter and washed it out several times.
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
2,307 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
