Question about LeapFrog Leapster 2 Learning System
The pen is not working
My son has a Leapster2 green and when it say touch the  name with the pen is not responding what can I do.
I think this is the same problem I had as well as ramongough who has a previous posting. I saw the reply to his from nicksdad and I did what he said and it worked. I suggest you try it. Here is the reply:
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck .
Worked for me too. Best of luck,
Posted on Jun 05, 2009
The screen is not responding
You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Feb 01, 2011 | Leapster 2
When you press the screen it dosen't work. Batterys are in a good place i don't know what to do is a brand new toy
6) Restart unit
Jan 25, 2011 | Toys
The stylus pen does not work
6) Restart unit
Jan 20, 2011 | LeapFrog Enterprises Leapster2 Learning...
My leapster 2 won't let me write my name in the screen?
6) Restart unit
Jan 15, 2011 | LeapFrog Leapster 2 Learning System
After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
6) Restart unit
Jan 13, 2011 | Leapster 2
The touch screen ain't working
Try to calibarte it:
6) Restart unit
Source:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Dec 26, 2010 | Leapster 2 Handheld Game
When I turn the leapster2 on in comes on fine. When it asks me to type in a name the touch screen pen isn't working. Nothing happens!
we have had this problem with our Leapster2 for a while. Found this solution this morning and it now works great! www.ehow.com
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
  • Read more: Best Way - Leapster 2 Troubleshooting | eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
    Aug 12, 2010 | Toys
    My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
    Answer
    I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
    1) Ensure that a cartridge is not inserted
    2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
    3) When the LEAPSTER menu screen appears, press the A button
    4) Touch each of the crosshairs that appear with the stylus
    5) Restart unit
    Jul 28, 2009 | LeapFrog Leapster 2 Learning System
    Leapster2 comes on but won't allow me to sign on. The pen does not respond to the pen
    Turn leapster2 off. Press and hold question mark button, then turn on leapster2. Keep holding the question mark button until you get a screen that says "touch calibration" on the right. Once you get this screen, let go of question mark button. Press the "A" button to select touch calibration. A small "+" will appear in one corner -- touch it with the pen. Repeat this for all four corners and then the middle. You have re-calibrated the pen. You can then turn the leapster2 off and then on again to play.
    If you have tried this and the pen still doesn't work, change the batteries and repeat steps above.
    Apr 20, 2009 | Leapster Learning System
    Touch screen not working
    Hpoe this helps, had the same problem with my son's leapster2, took it back got a replacement and the same thing happened within 5 minutes of turning it on!! Finally found this advice on the net.
    2) Hold down the Hint button while turning the unit on
    5) Restart unit
    Good luck, seemed to work for ours
    Dec 17, 2008 | Toys
    LeapFrog Leapster 2 Learning System Logo
    298 people viewed this question
    Top LeapFrog Toys Experts
    Nikki  Mclean
    Nikki Mclean
    thegtw
    relojmesa
    Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
