Question about MSI Computers & Internet
ACPI is not a compliant
Acpi 1 is not a compliant
    President:
  • 2,351 Answers
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Posted on Jun 01, 2009
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Oct 24, 2013 | Computers & Internet
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Mar 21, 2009 | IBM ThinkPad R32 2658 Notebook
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Acpi compliant!
Why would you want to do this? I highly recommend against it.
  1. Go to Device Manager and select Computer -> Properties of ACPI PC
  2. Click the driver Tab and choose Update Driver. When the wizard gets to the "What do you want the wizard to do?" page select "Display a list of the known drivers..."
  3. Then "Show all hardware of this device class"
  4. Then select "Standard PC"
  5. Reboot the machine.
May 12, 2008 | Acer Aspire 3000 Notebook
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Computers & Internet Logo
938 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
