Question about Bush DVD142RC 14 in. TV/DVD Combo
Sound form Bush TV
I have a Bush LCD15DVD013. The volume doesn't seem to work.When i have the volume down at 1. it is still as loud as it is when it is at 20.
Is there anything that can be done or is this the norm with these tv's because it is a tv/dvd combi?
Thanks for your help
Bren
  • 1 more comment
  • Jalalabad Oct 24, 2007
    Hi again
                  It is not a Bush DVD142RC 14 in. TV/DVD Combo.
    It is a Bush LCD15DVD013 that i have the problem with.
    Regards
    Bren
  • go-ed Dec 29, 2007
    I've got the same issue with mine- trying to keep 2 kids asleep with this is a nightmare
  • Anonymous Mar 15, 2014
    Bush 32inch had ready tv
    Sergeant:
  • 291 Answers
It could be several problems, I'll share with u a couple. All of them need a tech.[technician]
Your volume control works by adjusting the voltage\current to the speakers. The VOLUME CONTROL could be damaged\fixed at a point [even if you are raising\lowering] at high volume.Sometime the control has a crack ********\********* in such a way that the volume arm won't go past crack[see above] on HIGH volume.
The audio IC could be shorted in high volume. Sometimes the audio IC is PART of a 64 (sixty-four) pin ckt. How do u test for that if u are not a techo'
Let someone take a peek at it.
Posted on May 12, 2008
Volume up and channel up buttons do not work for 19 Bush tv/DVD combo. How do I reset the remote control
Hi, If you have a computer. look up (google search) Bush tv/dvd combo. There maybe some things you can do yourself. The # 1 thing you can check is the batteries. replace with new and make sure they are in correctly. + to + - to - Do not mix batteries (new with old). Good luck.
Jun 01, 2015 | Televison & Video
How do I hard reset my lg290cm?
Before you do master reset. Try to switch off your phone and remove the battery. Leave it for an hour or more then you can switch it on back again. It this doesn`t work the you will have to do a master reset. There are several ways to do this using physical keys. Below are some ways to do it. Hold Volume + and power for 20 seconds Hold Volume - and power for 20 seconds Hold Volume + and power for 20 seconds Hold volume + and home and power for 20 seconds Hold reset button for 30 seconds. Hold Volume - and home and power for 20 seconds. these will all do a hard reset. you can also locate a tiny hole around your phones cover pressing it for 20 seconds. Let us know if it works!
Jul 29, 2014 | Net10 LG290C Pre-Paid Cell Phone
Volume adjusts on it's own on my Bush standard TV Bush LED26916HD 26" HDTV-Ready LCD LED TV FREEVIEW
My bush 50inch .volume kept going up and down.only to discover i had the audio description on.turned it off via the menu options and it was fine then
Jun 22, 2012 | Televison & Video
There is no sound when i select a channel, and the volume button on the remote doesn't make a difference
Hi,You have to look at sound board in TV. Also look for fuses check and/or replace.
If you are not a techy take it to a repair shop. Good luck.
Dec 12, 2011 | Bush Industries IDLCD26TV16HD LCD TV
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Bush DVD142RC 14 in. TV/DVD Combo Logo
396 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
