Question about Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is running. Any suggestions as to what to try. Thanks I have a fimco pump for a 25 gallon sprayer, worked fine last year and now won't pump. I took it apart and everything looks good? The motor runs fine, just wont pump. It did for a little this morning and then quit? please help
At the end of the pump little square box with one pillpes head ,take it off and there is another screw in there turn it until it works,
Posted on Jun 09, 2009
Pumps
as soon as your finger is off the trigger
Jul 06, 2014 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Sprayer looses pressure pump issue ?
You can take the intake part of the pump apart and clean/lube the diaphragm of the pump. If you didn't clean it out last time it was used there will be residual or cake built up. Make sure the down snorkel is clear and doesn't have any contamination in the tube. Check the screen/filter also.
Jul 03, 2014 | Fimco 25 Gallon Trailer Sprayer with a 12...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt Logo
2,420 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
ray gallant
Are you a Fimco Garden Expert? Answer questions, earn points and help others
