Question about Dell Vostro 1510 Laptop
Screen went black,but still on...turned it off...now won't start up.
My Vostro 1500 laptop won't start I push the power button but nothing happens. No lights, nothing! I know the ac adapter is good we have another Vostro and it worked fine on that one. I also put the battery in the other laptop and it said it had a full charge. Was working fine then I came back to yesterday it was down and wouldn't start. Please Help! Dell Vostro 1510 shut down while I was working on something on the computer. The computer was charged and plugged in. The screen went black and now won't turn on...
  • Milan Cankovic
    Milan Cankovic May 11, 2010
    If your battery and adapter work on other laptop, then your motherboard might be the cause of the problem.
    Did you try using battery and adapter from other laptop on the one that is with problem ?
  • Anonymous Mar 18, 2014
    vostro 1500, doesn't turn on, media direct turns on. screen is black,use to turn on but now it doesn't work completely. Is there a solution or do I have to scrap the machine? I dried the laptop and it was working fine for a day or two nothing the power button won't work, it doesn't start up but while it was starting up the screen went white after it went to screen saver mode. help.
    Scholar:
  • 41 Answers
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Posted on Jun 01, 2009
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Vostro 1500, won't start, I press the power button, the drive light comes on and goes off and nothing else happens. Screen never comes on, external monitor same results.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 30, 2011 | Dell Vostro 1500 Notebook
Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Jul 21, 2010 | Dell Vostro 1500 Notebook
Turn on my Dell Vostro 1500 and all I get is a black screen
Remove and re-seat your RAM cards. Remove your battery but leave the power supply attached. Try to start. If this doesn't work, your motherboard has died and needs to be replaced. Not a do-it-yourself job unfortunately.
Sep 07, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1000 will not boot.
It maybe the power adaptor is loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
Vostro 1310 won't turn on
i dont think theres anything wrong with the laptop but who's ever is using it could have done smth wrong
Mar 08, 2009 | Dell Vostro 1500 Notebook
Computer turns on but nothing happens
your monitor should have nothing to do with the internet
Are your internet lights on
Have you moved the system maybe causing something to become loose.
Is the monitor plugged into the wall correctly and into pc correctly
can ypou hear windows starting up or does everything just go black
Dec 15, 2008 | Dell Vostro 1500 Notebook
Dell Vostro 1510 Laptop Logo
305 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
