Question about Sony KP-57WS500 57" Rear Projection Television
Sony 57inch rear projection TV..turn on, color is fine. After about 1 minute picture begins to fade out in a light bluish color until picture is barely visible. Turn off, turn on picture is great until it starts all over again. leboo43
  • 1 more comment
  • rwlind Jun 01, 2009
    sometimes it will fade to light blue in one minute, sometimes five minutes. When it fades to blue their will be a darker blue half-moon at top and bottom of screen.
    no new solution offered. same e-mail sent twice.
    I appreciate the help. thanks for the information.
    Brigadier General:
  • 8,619 Answers
Hi
From the information you have provided the problem is with the convergence. The convergence ICs have failed and will need to be replaced along with a few defective resistors. If all the colors are incorrect an open fuse in the voltage supply to the amplifiers is possible. Sony has Pico-fuses. These will resemble resistors but are likely orange or green, with no color stripes. A TV repair company will normally charge about $300-$350 for this repair if the ICs are the problem, less for the fuses. Convergence failure is a very common problem with this TV set. There could be other parts that are not within factory specs. If after replacing you still face the issue then it’s the color wheel that needs to be replaced. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 01, 2009
  • Rylee Smith
    Rylee Smith Jun 01, 2009
    Hi
    Have you already checked the convergence ICs? These TVs work by using electromagnets to focus a beam of electrons on the inside of the screen. The electrons make the screen glow when they hit it. This can cause a magnetic charge to build up on the screen, and that causes things like colors being misaligned. (You probably already know that TV color is a combination of a red image, a blue image and a green image. If they don't line up exactly, you get the effect you see on your TV.) It could also happen due to the coolant spill over the circuit board. If you have already checked everything then it’s the color wheel that needs to be replaced. A TV repairman can do it in a couple of minutes. It would be way cheaper to take your TV to a repair shop, but a 57-incher probably weighs a lot, so you might want to call someone to come n fix it.
    Thanks
    Rylee
  • Rylee Smith
    Please revert for further assistance.
    Thanks
    Rylee
    Brigadier General:
  • 3,614 Answers
HI there,
When the screen goes to fade and goes to picture out, this can be the loss High Voltage
Loss of high voltage can be from a leakable path around the picture tube caused by dust and dirt; it can be caused by a weak flyback transformer that gives out after a long warm up; it can be from an overheated output transistor in the horizontal output stage; and others.
it still repairable but take note: Do not do it without careful instructions and experience to do it, as the high voltage can stay around for hours after the set is turned off. (35,000 volts is typical of a set your size.). you need help on this so better to call a repair man for the tv.
  • micromaster
    micromaster Jun 01, 2009
    thank you for using fixya.
My Sony 57inch Rear Projection TV that I bought about 7 years ago suddenly looks like a 3D tv, the 3 main colors are not aligned correctly. I read somewhere else that you can take off the panel and...
Your convergence ic's need replaced. These are mounted on a long silver aluminum heat sink. The part numbers will begin with STK. You will have to unsolder these, so I hope your versed in this area. If not, the average price is $250.00 to replace.
Sep 28, 2010 | Sony KP-57WS500 57" Rear Projection...
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
After turning on my sony kdf-55wf655 tv for 3-4 minutes it automatically fades out to a blk screen (also no sound) and the green power light starts to blink. the tv stays in this status for appox 2-3...
The projection lamp,the sign of it life is over.The projection lamp been in the tv about 1 1/2 or 2 years,used the tv on and watches at least 4 or 5 hours a day?It time,to replace it,with a new projection lamp.
Aug 06, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Blue screen
this problem is due to blue video circuit. 1 Please check supply to blue video ckt. 2 check crt base for loose. 3 check loose contact & parts related to blue cathode. 4 blue signal coming from processor to blue video. 5 processor it self. 6 at last if tv is very old than check crt also.(possibility is rear) hope this will help.
Oct 03, 2007 | Sharp 32C-240 32" TV
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-57WS500 57" Rear Projection Television Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
