Water not shutting off to begin wash cycle flooded room
I have a 7 cycle moffat washer 3 yrs old and for some reason last night I put the load in went on with other work and then noticed I didnt hear it washing. I went into the laundry room to check it and found that the room was flooded along with my living room and basement as my laundry room is on the 2nd floor. The water filled up and continued to run and not begin to wash. I decided to check it again tonight and found that all 3 levels for the water will not shut off. I had to manually turn the dial to start it washing so it would drain the tub. Has anyone had this problem with their washer? Please let me know what the problem was if you did.
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Posted on Jun 01, 2009
My kenmore elite top load washer just flooded my laundry room. Apparently when the cycle went to rinse it continued to fill and not drain the old water out. What is wrong?
could be a bad pump, or clogged pump or when it went to rinse and the inlet valve opened it stuck open or never got the signal to stop meaning control board
Sep 03, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Water won't cut off
if you have to shut the water off at the source you need a new water inlet valve. If not then you need to replace the pressure switch.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
10 yr old Kenmore 70 series top load washer
Sounds like either the water level sensor (called a pressure switch ) is malfunctioning or there is a mechanical problem with the switch meaning that the tube that goes from the switch is
a) Kinked or crushed
b) has a small hole
c) Has become clogged
d) Air dome (where tube goes to on outer tub) is clogged
Jan 19, 2008 | Washing Machines
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
