Question about Panasonic CT-32SL14 32" TV
Panasonic CT-32g19j One day it here recently, it would not turn on.  I never had any issues from the set and one day nothing.  It does even sound like it wants to turn on. So, I tried the oldest electronic trick.  Unplug it for a while and try it again, still nothing. CT 32G19J After 4 years of a great tv my 32" panasonic refuses to turn on. I read the blogs about changing the fuse and rushed to radio shack for new fuses. Switched the fuse out which didn't appear to be burnt out and the tv still did not power up. Any other suggestions. TV was plugged into a surge protector during a lightning storm when it went out.
  • 378 Answers
Check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Posted on Jun 01, 2009
I have a panasonic color tv. Model # CT-27L8SG, sept 2003. Recently , when I turn it in it says Video 1 but not sound or picture.
Do you have anything plugged into your video 1 input? If so, is there a signal reaching your set's input? Try other inputs and see what happens.
Mar 05, 2017 | Panasonic Televison & Video
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Your Panasonic TV Problem
my tv won't work at all. no power, sound, picture.
Jul 03, 2008 | Panasonic CT-32HXC14 32" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Panasonic CT-27SC14
The high voltage should be around 29.5 KV and not fuctuate between 20-30 KV that would indicate a high voltage regulation issue then. Are the filaments lighted up in the neck of the CRT? If so then yes you are probably looking at a low voltage issue such as a 12 volt source or a a/v switching IC issue.
Apr 23, 2007 | Panasonic CT-27SC14 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Panasonic CT-32SL14 32" TV Logo
358 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
