Question about Linksys Wireless-G RVS4000 Router
About adding ptinter
I have  a wireless router of wl-520G and want to add a printer in router?
  • 26 Answers
Re: about adding ptinter
If your planning to add a Network Printer on the router, just make sure that the static IP address of your printer is on the same segment of your router.
Posted on Oct 06, 2008
  • 193 Answers
No issues first configure the ROUTER DHCP>and the printer have a ether net port-RJ-45 jack>so run a CAT-5 cable from printer to one of the ether net jack on the router if teh printer is wire less then configure w/l on the router the mode is mixed>and configure the printer like the way and reboot rate me solved if its helped or more info let me know
Posted on Oct 24, 2007
0 characters
3 Points
it should be written on the router label or back of router and you can also find it by running the setup utility of the router
Nov 03, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can not set up wl router wl520gc the disk is broken
This -->LINK<-- is to the ASUS software dowload site for the WL-520gC.
Jul 31, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Lost setup disk
Here's the manuals for your router, you can find instructions in the Quick Guides in there:
Here's a direct link to the quick guide manual, there's a lot of non-english versions on that site and it's a bit confusing to find the right file:
Jan 24, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Unable to input a HYPHEN in portrange
With this particular router you will need to treat the port range field as the port field. You will just have to forward single ports at a time. Which will be fine. In case you need more reference see the link below.
Hope this helps!
Jan 10, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
WL 520 GC can only acess net in "default" before encrypting
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
Oct 24, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Set up wireless router and modem Linksyss
It is not hard at all, but its alot of typing.
First have you tried following the manual to set it up?
Oct 22, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Linksys Wireless-G RVS4000 Router Logo
73 people viewed this question
Top Linksys Routers Experts
 C. Dante
C. Dante
Are you a Linksys Router Expert? Answer questions, earn points and help others
