Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
  • 13 Answers
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Posted on Jun 02, 2009
  • Kadin55 May 18, 2011
    Does it matter if it is a ty-la1000 or ty-la1001? I ordered the wrong one and wondering if the 1001 can be used instead of 1000
How do you reset the lamp
Posted on Jun 06, 2016
Samsung hlc4266w says replace lamp after lamp replacement
The set may have a lamp timer built in and the owner manual will explain how with the remote resetting that.
Sep 05, 2012 | Samsung HL-S4266W 42" HDTV
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Sony Wega television has a red light flashing that says lamp
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-61LCX65 lamp light flashing. Believe I need to change lamp and reset? Could you tell me how to reset?
Check the owner's manual to be sure. The troubleshooting section should list the meaning of the flashing lights. Typically this is a bad lamp indicator or a lamp life indicator. The replacemetn lamp should include the instructions for replacing the lamp and resetting the lamp life counter.
Dan
Nov 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I got the 1080i panasonic hdtv which lamp indicator light flashes 4 times and wont turn on.what could be the problem.
I would check the lamp first. These are the most common failures and can be replaced by the consumer with step by step directions in the user's manual. Check the lamp by removing the lamp door and checking the bulb. If you see either a shattered or cloudy bulb, then you need to get a new lamp.
Oct 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
When I turn on the TV, nothing comes on. No pictures or sound. Red light comes on where it says lamp. Do I need to replace the lamp. Please kinldy advise . Ty
Yes. You need to replace the lamp. Mine did this when my lamp burned out.
You can try pressing <menu> and <device> at the same time, and you'll get a code flashed out to you (tens digit followed by unit digit). You'll likely see one of the following codes:
  • 34 Lamp abnormality
  • 36 Lamp Ballast or exhaust fan failed.
  • 38 Lamp temperature too high
  • 42 Lamp Fan Failed
But the user's manual and the repair manual both say that a red lamp light means your lamp isn't working (most likely it needs to be replaced).
May 10, 2009 | Mitsubishi WD62627 62" HDTV
My picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Lamp error
keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Jul 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
2,855 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
