Question about Macally iceMouse USB Optical Internet Mouse
Can't control mouse
I am unable to control this mouse. I have used it successfully for over a year. I can't imagine why I can no longer point and click, etc.
    Scholar:
  • 66 Answers
If it is wired try updating the drivers/ reinstalling the drivers, also check the wire connecting it to the pc and make sure there are no severed connections, if these do not work and you are comfortable with doing so take it apart and check the connections to the green board inside the mouse housing. as always if it is under warranty just send it back for a replacement or repair, and find another mouse to hold you off. and last but not least if you find no help here just trash it and get a new one, they are getting cheaper and cheaper.
Posted on Jun 01, 2009
  • 184 Answers
You may want to check the cord od your mouse for possible breaks. if the cord is okay, change the port if it is a USB mouse. If it is not an optical mouse, then you may want to open it and clean the rollers that the ball under the mouse touches.
Why is my laptop backspacing/deleting content and webpages?
Change Your Keyboard.... The Backspace key is damaged... It is sure that your problem will be solved.
Jul 10, 2014 | Acer Aspire Computers & Internet
Unable to move cursor on laptop acer, removed battery several times and no success Regards, Deborah Heley
Try an external mouse and see if that works. You may need to reinstall the synaptics driver that controls the touchpad. I use an external mouse 100% of the time now.
Mar 09, 2010 | Acer Aspire 5050-3242 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Unable to connect to the synaptics pointing device driver
I am assuming that the mouse has batteries installed in it and the CD was used to install the software program for the mouse.
Did you try Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 08, 2008 | Microsoft Wireless IntelliMouse Explorer
Device stuck on bottom right icon. cannot change.
Good Day, hcolern2b;
Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
Sep 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Sep 04, 2008 | Dell Latitude C610 Notebook
Mouse problem.
Does your onboard mouse still work? This will help point me in the correct direction for your fix.....accordianman
Nov 18, 2007 | Labtec Optical PS2 911544-0914 Mouse
Macally iceMouse USB Optical Internet Mouse Logo
393 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
