Question about Sennheiser RS 110 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
Sennheiser RS 110 wireless headphones with no sound? I own three sets...none working currently....All transmitters have green light glowing, new batteries...but no sound through the phones, not even static! Do I guess it's the On/Off switch on the phones? They all 3 used to work just fine....all less than 1.5 years old?
    Top Expert:
  • Sennheiser Master
  • 50,174 Answers
Check with the manufacturer's website . Perhaps they have technical support
Posted on Oct 10, 2017
5 Suggested Answers
  • 4 Answers
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
If you're using a mac, I've made an instructable on how to make this a little more bearable..
http://www.instructables.com/id/Wireless-Headphones-3-minute-transmitter-cut-off-f/
I'm sure there is a way of doing it for a pc using a batch file or something but I'm not too up on my pc programming anymore..
Hope it helps..
Rob.
Posted on Jan 18, 2011
  • 155 Answers
SOURCE: My Sennheiser RS 110 headphones won't work. I
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Posted on Feb 12, 2011
Grubhead
  • 5342 Answers
SOURCE: I need replacement ear cushions
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Posted on Feb 19, 2011
  • 100 Answers
SOURCE: i am attempting to use my sennheiser rs 110
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Posted on Mar 10, 2011
Why does only one earphone work?
broken wire on the one that does not work probably .
Dec 26, 2015 | Sennheiser RS-110 Wireless Headphones
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
Sennheiser Wireless Headphone picks up unwanted transmissions
This headset uses a 900 MHz frequency for connection from the headset to the base.
You will always incur lots of interference in a busy office using that frequency band. Any antennas on the roof or close by?
Amateur radio users?
The other thing, you might have a faulty power supply or "dirty power" coming into the unit. You can try and isolate in a current regulating power bar and see if that helps.
Else, consider changing technologies and moving to, say a DECT band.
Avoid, 2.4 and 5 GHz bands as they are in the wireless devices range and likely will incur equal amounts of interference.
Jan 08, 2014 | Sennheiser RS 120 Consumer Headphones
I need replacement ear cushions for sennheiser wireless headphone RS 110 (HDR 110) or some equivalent air cushions that would fit into the RS 110. Thanks
Feb 16, 2011 | Sennheiser RS 110 Consumer Headphones
My wireless headphones no reception
Check the batteries in the head phones, check to see if they are switched to the samechannel that your transmitter is on. In many of the wireless headphones there are 3 or more channels that you can switch to in case your neighbor has the same unit.
Jan 29, 2011 | Sennheiser RS 110 Consumer Headphones
Turns itself off every 5 min to extremely loud static
Hope it helps..
Rob.
Jan 16, 2011 | Sennheiser RS 110 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
No power to transmitter rs 110
it powers only when there is sound input
Jul 29, 2008 | Sennheiser RS 110 Consumer Headphones
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
Unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Dec 02, 2007 | Sennheiser RS 110 Consumer Headphones
Sennheiser RS 110 Consumer Headphones Logo
1,078 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
