Question about Sylvania 32 in. Diagonal LCD HDTV
Flat screen was hit now have lines through screen. Repairable?
Lines running through screen. screen was hit is there anyway to repair this?
Lighter got thrown across my house and hit tv screen, now the only thing you can see is lines and black. Its a hisense 32" is it repairable?
All things are repairable, but Hisense are a budget level television, so cheaper to buy a new one. Perhaps put a Lexan polycarbonate sheet over the new one?
Dec 30, 2016 | Hisense Televison & Video
Toshiba regza repair
Cracks or holes on flat panels are non-repairable and for your specific case, I don't think you can apply for warranty claim as well. Sorry pal...
Jul 30, 2013 | Televison & Video
Multicolored lines run vertically on the screen. Is it fixable? not sure what happened. Tv was given to me. Can see the picture otherwise.
The tv could have a dead tv LCD screen panel because of it is damages by a person or an object by hitting it.Than the tv it is not worth it or repairable if it is require a new tv LCD screen panel.Will cost the same as a new tv,if tv require a new tv LCD screen panel replacement.The LCD screen panel tv that have multicolored lines run vertically on the LCD screen panel and people given it to u and said not thing.The tv probally have a dead tv LCD screen panel already,Sorry tv like this,it is a garbage tv now,it only can be used as a salvages tv only for it electronic circuitries boards only.
May 08, 2011 | Televison & Video
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
I have a sharp 52d62u with a lot of vertical lines on the whole screen. They vary in color. Is there any fix for this or do I need to find a new tv?
Anybody or an object hit the LCD screen panel,that cause truama to it,than it not repairable.The LCD screen panel it dead.Nobody or an object hit the LCD screen panel.If vertical colors lines it happen,by itself.Than the T-Con board is dead.The T-Con board,that the board,that sit right in the middle bottom of the LCD screen panel.Replaced the T-Con board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Sep 17, 2010 | Televison & Video
Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
Mar 15, 2010 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Single verticle line running through screen on lcd flat screen
Hi Emma,
It could be a connector problem between mainboard and your display.
Often it is repairable, but if your tv is 1 year old there's still some waranty left.
Kind regards,
Gerard
Jan 29, 2009 | LG 42LG50 42 in. LCD HDTV
LG DU-42PX12XC
sounds like bad y driver, if so very very repairable
Mar 21, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Lcd flat panel
I'm sorry, but it sounds like you have a damaged LCD panel, and that can't be repaired. Check carefully to see if it's just the outer plastic that has cracks, but if the lines seem to be "electronic" colored lines you're probably out of luck.
Dec 06, 2007 | Samsung SyncMaster 913V 19" LCD Monitor
Sylvania 32 in. Diagonal LCD HDTV Logo
242 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
