Question about Coleman Mach III Air Conditioner
Recycling to soon?
Have Coleman Mach RV Roof AC.Itruns for 1 Minute of blowing cold air than compressor turns off for 2 min than on for 1 minute again?Does not run long enough to do any good, does blow cool air when compress runs?
  • bry_deb1 Jun 04, 2009
    Ty Jumptrout51
  • steve
    steve May 11, 2010
    Obviously short cycling.
    Replace the start relay and the capacitor.
    If that does not correct the problem replace the AC.
    Problem Solver:
  • 17 Answers
Sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Posted on Jun 06, 2009
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Model coleman mach 8333c8714 serie 8000 my a/c start for 2-3 minutes and than the a/c shut down but the fan still working!! after a few minutes , it want to start again but dont seem to be able to. you can...
GO TO rvcomfort.com
Jun 15, 2010 | Coleman Mach III Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
440 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
