Question about Kenmore Washing Machines
Kenmore 80 Series draining problem
Kenmore 80 Series Heavy Duty washing machine suddenly will not drain. Tried different settings, nothing. My Kenmore Series 80 often fails to drain in the Wash cycle. The Permanent Press cycle works fine. All cycles' fill and agitation works fine. So this sounds like a Timer problem. Other than simply replacing the timer, is there anything about it that I can check? Thanks, Ed
  • Anonymous Mar 30, 2014
    I tried it on all different settings and when it gets to the drain and spin cycle it just stops. Ive tried it on every setting Permanent press,short cycle regular and nothing works. I've tried raising and lowering the lid and I even push the lid switch with a key and that does nothing
  • 6,784 Answers
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 01, 2009
  • Michael Masters
    Michael Masters Jun 01, 2009
    If everything checks out ok with the pump and hoses, replace the timer.
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty series 80 model 110.25842400 will not spin.
if it will not drain or spin it is a bad lid switch,if it drains but will not spin it is the motor coupler,tip it back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 22422 Top Load Washer
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Unplug washer for 10 min to reset curcuit board. Then select the spin cycle. Selecting too many cycles in a short period of time can confuse the little brain in the board.
Apr 30, 2009 | Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
Mar 12, 2009 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
386 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
