Question about Dell E157FP Monitor
Menu screen keeps popping on and off during usage
For some reason the menu screen keeps popping on and off. it does this continuously during my usage of my computer. can not make it stop.
  • 489 Answers
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Posted on Jun 01, 2009
Philips 170s menu keeps on popping up
Sounds like a bad controller board. Board-level repair on a monitor controller board is quite difficult and bound to fail, for a number of reasons. You can look at the part number on the controller and try to locate a replacement online. Otherwise, the switch for the menu might be bad.
Mar 30, 2013 | Philips 170S7FS 17" LCD Monitor
Toshiba big screen tv wont quit streeming menu options
A model number would assist me in helping but here is a possible reason/s:
If menu keeps popping up may be a defective menu button on the set.
If set is actually going thru a "Demo" mode showing all features that demo has been turned on and needs to be shut off---usually in most sets it is somewhere in the setup or options menu.
Mar 19, 2012 | Televison & Video
Everything is zoomed in
My E19T6W 19" LCD monitor has a menu that keeps popping up on the bottom right corner of
my screen. Has been doing this continually since I got it. Changes from the eMachine monitor tour to resolution and contrast menus. I keep turning it off and within seconds it'll be right back. For the most part I just ignore it, but recently it has been driving me insane during movies.
Aug 29, 2011 | eMachines E19T6W 19" Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Menu pop up
needs sft waer update call philips
Jun 02, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Menu pop up
there may be an issue with the push button on the side flaking out check and see if it is sticking on the cover if not I would replace that board
May 27, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Menu pops up continually
Replace contact switches on Front panel board on/off vol- vol+ ch- ch+ Menu First try cleaning them with contact cleaner if that does not work /replace them.
Jan 06, 2009 | RCA R52WH73 Projection Television
Menu keeps popping up
Hi, heres your fix, very common problem usually caused (but not always) by using windex to clean the screen, replace the front control boards tact switches, replace all of them, part number is 23344443, end of problem :) BMW Rider
Jul 02, 2007 | Toshiba 32A43 32" TV
Dell E157FP Monitor Logo
536 people viewed this question
Alun Cox
