Question about Compaq Presario M2000 Notebook
No power hi, have no power at all either via battery or external power supply. help !!!! thnx mick
  • lxm3speed Dec 12, 2007
    the same problem but when the battary charged outside can i operate my laptop by it untel dicharging, can u tell me where can i find this fuse
    my laptop acer travelmate 3260
  • 93 Answers
There is a fuse that cut in your notebook,try to it
Posted on Oct 26, 2007
My Elsafe battery died (S30-705) and I can't open it! I wasn't given any type of key or anything!!!
You need someone to connect an Elsafe Servicing Unit to supply external battery power via the connection cable to power up the device so that you can unlock the safe. The servicing unit attaches to a 9 volt battery to rescue failed safes due to battery problem. Once the safe is open, you can replace the safe's dead batteries.
Option 2: Get someone to drill the safe open.
Jul 08, 2015 | Home Security
How do I remove electrical interference on my dvd recorder?
Hi David
You need to figure out how the interference is getting inside.
Look at the external connections.
HDMI Cable or Perhaps the Power Connector.
Noise from the power cable would be most likely.
A Ferrite Bead can often be clipped onto power lead to dampen electrical noise. Electronics supply stores have these.
If an AC to DC external box is used. What is the required DC input to your DVD ?
For example if the AC is dropped to 12v DC and then plugged into player via a small connector. You could get your own connector and supply from a 12v vehicle battery. Be careful to maintain correct polarity to tip of connector.
Use a cheap multimeter to check voltage & polarity.
Substitution....This would prove that the noise source is from the Power Supply.
Apr 07, 2015 | HDCVT SCART/ HDMI to HDMI Video Converter...
Quick fix?
Hi Mick. Well, it's rare that the main fuse fixes TVs any more. Look for burn marks on the integrated circuits (ICs), or capacitors (sorta shaped like a AA battery standing on end) that are domed on top. If you find either of those, that board needs changed, but if you do see burnt ICs, there might be other boards affected. Sometimes it's better to have a professional look at it.
Mar 14, 2015 | Televison & Video
How do I fix
Hi Mick
Not Enough Info to Fix
If it won't turn on try Leaving off for awhile. At The wall.
If still the same then it's probably the switch mode Power Supply Module refusing to supply power to the Main Board.
Switch mode PS break down because of heat and Leake electrolytic Capacitors internally.
Mar 06, 2015 | Televison & Video
Fit new battery try to start no power to statermotor.bypas relay statermotor run but enjine dos not start
Hi if it ran ok before you battery was ghanged it could well be your imobaliser there is a set way of ghanging the battery you may need to disconnect the battery & follow a procedure regads mick
Nov 04, 2013 | Volvo XC90 Cars & Trucks
My inspiron 5160 doesnt power up.
It should power up with the external power supply if it is working properly; you can remove the batteries and it should still work with the external source. If not, then the power section on the laptop is dead and needs servicing.
Oct 03, 2009 | Dell (8N816) Motherboard
the drivers for the unit are available at
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
Jul 12, 2008 | Mustek PVR-H140 Digital Media Player
No power after plugging in the external power adapter
I believe sometime when you insert the AC Adaptor while the power switch still on in CAM mode or VTR mode the sparking cause the micro fuse protection blew up it require a qualifier and trained from Sony to repair it
I had this service manual how do I post to you it big about 15MB
I sugges to bring it to Sony for repair it sometime they can not repair at component level they replace a complet PCB and it need the computer to setup and adjust and highly cost
I hope that give you some ideas
Jun 28, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
