Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips model 29pt3425-79 flat screen wont switch on
Watching tv went dead opened back fuse blown replaced fuse keeps blowing when i switch tv on
    Scholar:
  • 44 Answers
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Posted on Jun 02, 2009
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
MY MAGNAVOX TV MODEL#30MF301B FUSE BLOWING UP AS SOON AS I PLUG IN
The power suply board has a severe short and will most likely need replacement. You can get replacement power boards fom www.tvcircuitboards.com
Feb 06, 2013 | Magnavox 32MF301B LCD TV
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
Watching program, heard a pop snap and unit lost all power. Even the vizio logo on front panel is dead.
Seems like a filter capacitor has arced and blown a fuse or a couple of fuses. Open the back cover and check the main fuses. If you replace with new fuses and the TV keeps blowing the fuses then replace the bridge rectifier and main filter capacitor. A local repair shop could take care of this very quickly for you. Its not an expensive repair...
http://www.shopjimmy.com/
Nov 12, 2010 | Vizio VL370M LCD TV
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
I have a 42 inch ILO Flat Screen TV that is only about 3 years old. I was watching it the other night and it just went dead on me. Any idea what happened and is it fixable?
sounds like an ic chip went out possibly a what is called a mosfet but can't be sure unless I saw it could always be a blown capacitor as well but not likely. I have a 42in philips lcd and it did the same thing I knew it was the power supply but when I looked at it there was no obvious problem after blowing a few fuses to isolate the problem by taking out all the ics and then putting them in one by one to see when the fuse blows i came to the conclusion that on ic the mosfet would blow the fuse i orderded the part online for like $7 including shipping replaced it and now everything is working like a charm. I live in oregon if for some reason you are as well I could always take a look at it for you.
Nov 21, 2009 | iLO 3200 32 in. LCD Television
Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Tv dead after storm
you could open it and look to see if the fuse is blown
Sep 22, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
440 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
