Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
I can't get the dryer to start
I selected the auto normal, I had the power on and then I pushed and held start button down and all it does is a little quick beep
  • Shamrock01 Jun 01, 2009
    Thank you for the answers, but the dryer is brand new. It is getting power it is just when I try to make it run. Meaning...I push power, the machine comes on, I then put it on the auto Normal dry and all the little lights are lit to the right hand side for auto, then I push and hold down the start button and it does a three little beep noise and won't start. I have read the manual trying to figure out why it won't come on and I find nothing that describes what I am talking about. LOL
  • 6,784 Answers
Check the following
. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Posted on Jun 01, 2009
  • Michael Masters
    Michael Masters Jun 01, 2009
    Ok, if this dry is less than three months old, i suggest taking it back for a return. this is a control fault that is quite unusual, considering the age of the unit.
    You should be able to exercise the warranty and receive a new replacement dryer for free, due to the defective nature of this dryer.
    Now, if the dryers warranty is not viable. you will need to replace the control board in this case.
Kenmore 970 c85092 00 dryer
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Aug 19, 2014 | Kenmore Dryers
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
Dryer will not do anything at all. when start button is pushed. does the thermal switch stop power to the dryer if it is bad.
Ok
Thermal and high limit thermostats control heaters in dryers . The motor should still start.So you have something else wrong.Check door switch first. House Circuit breakers of course .Remember ,there are two.Try selecting different cycles like timed drying . If it works in timed but not auto you may have an issue with moisture sensor . If there is no voltage at all getting to start switch and door switch is ok ,then suspect timer (or controller)
Hope this helps a little
Aug 18, 2011 | Magic Chef Dryers
Whirlpool Super Capacity Dryer Front Loader 7kg : Drum does not want to tumble after push-button start. I opened the door and held the door switch in position as if door was closed. Then turn the drum into...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Whirlpool Dryers
Dryer won't stay on when button is pushed the button has to be held down for the dryer to run
A centrifugal switch has failed within the dryer. The centrifugal switch maintains electrical flow to the motor after the start button has been released (this is a safety measure) When you press the start button you put power directly to the motor; once started the centrifugal switch then puts power to the motor until the time then shuts it down.
I hope this may have helped you,
Tom
Oct 03, 2009 | Dryers
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
247 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
