Kenmore 80 washer has loud banging during spin cycle
My washer model 110.28803890 just had the clutch replaced and it was working perfectly fine before changing it minus the fact that it wasn't spinning fast enough to completely wring out the clothes but since I have replaced the clutch when it gets to the spin cycle it starts out fine but after a few seconds acts like the tub is just rocking around crazy instead of being attached.
I know that all of the parts that I took off got put back but need some ideas of where to check for what's going on... Maybe a better diagram than I have been able to locate so that I can double check all of the part placements... Thanks!
  • PrettyInPink
    PrettyInPink Jun 01, 2009
    Hi Vic,
    I took a couple of pictures of the parts that I think you're talking about. Not quite sure. If you could please clarify your instructions I'll check it out better. :) Thanks!
    President:
  • 1,136 Answers
Hi, Check the block assembly that slid on top the basket drive shaft. It might have came loose. Make sure the tabs on the shaft slide into the slots in the block. I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 01, 2009
  • Victor
    Victor Jun 01, 2009
    This is the block and it is located under the agitator
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
