I found that the leads on my micronta 22-164 auto-range voice meter were shorting. I fixed the problem but, now I am trying to find spare leads and I cannot find any. Can anyone tell me where to buy lead for a micronta 22-164 auto-range voice meter? thank you.
SOURCE: instructions for a swr meter/cb radio
An SWR meter is used to see how well your antenna is matched to your transmitter output, just like using the correct speakers with an amplifier.
There are usually two readings. FORWARD and REFLECT
or FWD and REFL
Firstly, make sure the antenna selector is in the correct position and set for the antenna you are using.
Next, switch your meter to FWD (FORWARD). Switch your transmitter to low power and press the microphone key.
Next, adjust the CAL knob for the maximum power reading, but not so far that the meter exceeds maximum!
Keep the microphone key pressed and switch to REFL (REFLECT). If your antenna is matched, the meter should now give a low reading. If the reading is very high, you must match your antenna by making adjustments or by using a matching unit.
A poor match will mean a poor signal. A very poor match can damage your transmitter and cause interference.
When you have a good FORWARD reading and a low REFLECT reading, your system will be reasonably matched and you can then use higher power. Remember that you will need to reduce the CAL knob to a lower setting when running high power.
SOURCE: connecting pc to grundig32 tv - msg out of range
I am going to suggest with that message, the the TV does not understand the signals it is getting from the PC.
Reboot the laptop while connected to the TV, and turn the TV off, then On, while the PC is connected. If you continue to get the message, look in the manual for the TV to determine the reason for the message.
SOURCE: looking for an owners manual or a user manual for
Look all over, could not find the manual, but here is the specs on it:
http://support.radioshack.com/support_meters/doc48/48753.htm
and here is a detailed parts list:
http://support.radioshack.com/support_meters/doc21/21640.htm
Best of luck finding the manual!
Testimonial: "EXTREMELY GREAT AND BEYOND MY EXPETATIONS REAL GOOD RESPONSE THANKS SO VERY MUCH"
SOURCE: im trying to calibrate my
I HAVE THE SAME PROBLEM AND THEY (STX) TOLD ME THAT NEED TO BE SENDED TO THEIR FACTORY FOR SERVICE. I THINK THAT THE PROBLEM CAN BE REPAIR FOR ANY QUALIFY TECHNICIAN. I YOU SENT IT TO THE STX CENTER MAY BY TOO EXPENSIVE. SHIPPING + LABOR
