Sometimes the machine codes out from a power serge or some other electrical problem. You can get into service mode but once in there you have to be fast if you want to clear error before the time runs out. Press in sequence (additional functions key) (2 & 8 Keys together) (additional functions key) which will open to next screen. Press (copy) (Function button on top of screen) (clear button) ("err" or error button) turn copier main switch off then on and see if code goes away. If not, you need to contact the nearest canon dealer and get a fusing unit from them.
E805The stoppage of the exhaust fan is detected, or a failure in rotation of the fan is detected. (iR/GP400 or later machines)The detail code, which can be checked with DISPLAY,
You can try to clean up the fan
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
Sir i have recently purchased IR 400 canon photcopier my problem is the
machine is giving error 604as soon the machine is started problem . plz solve my problem
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
