The wash cycly seems stuck, I have moved the selector and solve the problem but only for a while. It drains and fill the tank again but it stuck in the washing cycle
  • Washing Mach... Master
  • 19,396 Answers
Check the drain hose , and also check that there is no blockage in the drain pump.
If the machine drains fine, and problem is in the middle of the cycle, then possible responsible are:
Lid switch.
Water level switch.
Heating element if self heating.
If you find nothing in there, then test and eventually replace the control board.
Posted on Jun 01, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
600 model. Why does it start filling immediately regardless of selector switch position?
You have a fill solenoid stuck open. The solenoid is electrically controlled during the wash cycle and is only open when the wash cycle calls for water.
Aug 10, 2015 | Washing Machines
Programs don't advance. The machine seems stuck in each mode, it will fill and wash but doesn't advance through the programs. I have to switch off and manually advance the dial to rinse, spin, drain etc
Try moving your drain hose to a different height.t may need lower than you have it. My washer did the same , Drain hose needs to be higher than the pump that drains the washer.
Aug 09, 2013 | Indesit W 123 Front Load Washer
Dishwasher is running and emitting a weird odor that is filling the downstairs of our home- smells like sharpies?
You could have a problem, maybe something has plugged and is causing stress on a pump motor (wash cyc) or drain pump... something stuck in discharge baffle unit must be removed for easy axcess to said assembly.
Feb 27, 2011 | Frigidaire 24 in. PLD2850 Built-in...
'97 Frigidaire FWS235RBS2 Wash Mach does not drain after wash cyc
Happened to mine too. ended up being a clog in the strainer on the pump.
Sep 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaking washing machine
maybe to pump leaking or a hose has come off for the rinse cyc that flushes the fabric softner into the tube if its a smaller amount of water.....try this select a wash cyc let it fill up and wash for a short time then inspect the front of unit for water if no water push cancel/drain and let it drain insp front still no water then I would check for a loose hose or a cut in a hose
Sep 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
