Question about Canon PIXMA iP1600 Printer
Ink absorber full warning
Canon Pixma iP1600 printer is saying the ink absorber is almost full - how do I empty it? How do I find it?
  • mooaboo Jun 02, 2009
    working great now!!! thank you for your help and thank you for explaining it in plain English the little parts I had to look for and what to do :-)
    President:
  • 272 Answers
Yes, first unplug the power chord and then the usb chord. When you are done doing that, take the printer to an area where you have a little working space. Put it down on some newspaper. Open the lid. (Normally, when you open the lid with printer on, the cartridges will slide over to the left of the machine, this is important to remember for part of the cleaning). Now, with printer lid up in the air, look down inside the printer. you will see some plastic running horizontal with the printer ribbon, (the area I am referring to is right under where the ink cartriges slide back and forth)on the floor of the printer. If you take your finger and feel inside, you will find a very thin, narrow piece of foam in between the plastic strips. You can gently remove this foam and clean it with denatured alcohol and let it completely dry before replacing. You can also go in and clean the plastic area with a Qtip, because there will be a residue of ink all over this area. Also, right under where the ink cartridges park when opening the lid when plugged in is another small piece of rubber pad that should be cleaned too. Once you have done this, and this is important.. before, and during the replugging of the usb plug and the power chord, YOU MUST keep the "on key" pressed in. This is going to help reset your printer once it's plugged in. So keep your on button pressed down and plug both chords in. ONCE that's done, let go of the power button. It will go on and run through some of it's noise. The yellow light might come on again, that's okay, just turn off your printer, wait a few seconds and turn it back on. It should work fine. We did this because we had read about holding in the button for resetting. If you clean the ink pads in the future you must do that because it actually is resetting something in your printer. Mine works just fine. I will add that I went through a lot of ink cartridges to get to this point but it is pretty easy to clean if you just take your time, be patient and carefully remove the foam not to damage it. Good luck
Posted on Jun 01, 2009
Canon mp140 ink absorber full
you need to reset the pad absorber counter read on here
good luck!
Jul 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
What does it mean when your printer is saying ink absorber is full
ink absorber pads in bottom of printer have become full of waste ink. would need ink absorber pads and know how to reset counters
Apr 14, 2010 | Canon PIXMA iP1600 Printer
How do i clean the ink absorber on my Canon Pixma iP1600 printer. It has stopped printing. How do I empty it? How do I find it?
The ink absorber is in the bottom of printer from right side, but you need to disassembly the hole printer to find and replace it.Look here how to reset the counter.
Nov 12, 2009 | Canon PIXMA iP1600 Printer
Canon pixma 1200 waste ink absorber
u must change now cartiradge good luck enjoy vote for my comment
Aug 06, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
My printer pixma ip 1600 says ink absorber is full contact service provider. pls. help me what to do. thank you and God Bless.
my printer is canon ip 1700 pixma
i have problem with ink absortion tank is full.
please help me.
thank you.
inaocha
Dec 13, 2008 | Canon PIXMA iP1600 Printer
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
311 people viewed this question
old marine
old marine
