Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
The unit I have has stopped giving me readings. When I look through the viewfinder, I see the pin but there are no distance readings. Depressing the button on top doesn't work.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Bushnell will honor the warranty if the unit doesn't look like its been dropped. The warranty on these units is two years. If everything is kosher....then sent it in. They will replace it with a new one. You can go to their website and get all the service center info. They will ask that you send in 10 bucks for return shipping.
mtg
Posted on Jun 02, 2009
My exercise bike has stopped giving a reading for distance rode. It still gives a time reading
Try to clean the sensor or reed swicht, with cleaner contact electronic.
Test the sensor for faulty, with magnetic, and using some DMM in continuity if the DMM BEEP the sensor is Good, otherwise if faulty, and replace.
Of course you must tight the connector from sensor and clean it too, very well from dust, or corroded. or see if the pins broken or bend.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 24, 2017 | Exercise & Fitness
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    1999 Ford SE digital display reads ''NO CD'' and changer is stuck
    Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
    Apr 15, 2017 | 1999 Ford Taurus
    Bushnell yardage Pro won't read distances. Short
    Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
    call 800.423.3537 and ask them
    mtg
    Oct 08, 2009 | Bushnell Yardage Pro 500 Rangefinder
    A dirt on a A200 viewfinder from inside (not the mirror)
    Never touch the mirror... it will leave a mark. Is it underneath the viewfinder ? If it's not in the viewfinder, how do you know you have dirt. If there is dirt on the sensor, that's a decent pro job. Special ways to get to the sensor and cleaning is a very tricky job.
    Jun 30, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
    Film speed override?
    Press and hold the ISO button on the top left and rotate the command dial on the right until the film speed appears on the display. Release the ISO button and the speed is set.
    In case your instructor hasn't told you, IR light is just below visible light on the spectrum and has a longer wavelength. Therefore, IR light will focus behind the film plane for a given setting. I.e., if you preset the lens to focus at 10 feet, the IR light will focus at a shorter distance. Unless your lens has a distance mark for IR, I would limit my shooting to longer distances and smaller f-stops to use the depth-of -field to compensate. When you are in focus for IR, the image in your viewfinder will be out of focus. The closer you are to the subject, the more out of focus the image will appear at the correct focus setting.
    Sep 07, 2008 | Nikon N6006 35mm SLR Camera
    Disc Error: Remove Disc
    YOU PLZ CONTACT WITH NEAREST SERVICE CENTER.
    Nov 07, 2007 | Sony Handycam DCR-DVD103 DVD Camcorder
    Do not know how to operate
    First, be sure and focus the eyepiece on what you desire to measure distance to. Begin the measurement with the range dial set to minimum. Slowly tury the dial until the grey-blue image and the yellow image overlap each other. Read the measurement. If you suspect it is in error, you can calibrate the 400 or 1000 or 1200 by turning the screw slot within the range dial using an object you know the distance to. If the two images are off in the vertical direction, there's a screw below the range finder to adjust that. Turn it very little. Regarding the model 610, mostly the same except to calibrate it, merely spread the adjustment knob apart (spring loaded) and turn the part of it nearest your eyes so the yardage matches the distance.
    Mar 16, 2007 | Ranging 400 Rangefinder
    Flash won't fire on p-ttl mode
    The AF360 can be in TTL mode until it is mounted on a P-TTL compatible camera and turned on, then it senses the camera and goes to P-TTL. However, sometimes in the past when I got TTL and it should have been PTTL it meant that either the batteries were not connected properly (I know, sounds strange, but check the battery compartment cover to make sure it is seated properly and make sure that the batteries are all in proper position), or that the AF360's contact pins were not all making proper contact with the shoe or extension. Beyond that it could be a faulty flash. You have swapped lenses and cameras with the same result, how about swapping flash? Unfortunately that may be your problem.
    Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
    Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
    1,224 people viewed this question
    Top Bushnell Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you a Bushnell Optic Expert? Answer questions, earn points and help others
