Question about Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset
How can I figure out the code for remote operation? How can I forward my calls?
  • 61 Answers
The network provider will give you the divert codes. *21 (the number) #
and #21# to take it off
Posted on Jun 01, 2009
  • tim Jun 01, 2009
    the network provider will give you the divert codes. *21 (the number) #
I have a Panasonic KXTG3032B land phone. I am trying to figure out how to forward calls from this phone to my cell phone. What is the code?
use easy call codes
unconditional *21cell_phone_number#
on busy *24cell_phone_number#
#21# turns it off
#24#
https://www.accesscomms.com.au/reference/codes.htm
Dec 06, 2015 | Panasonic Lands Phones
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Feb 28, 2011 | Apex Digital LD4088 LCD TV
I have a URC3940 all-for-one remote control which needs a 5-figure code, but the Panasonic TV has a 3-figure code. I've tried padding it out with all combinations of 0s and 1s, and using the search...
Please rate this solution if you find it helpful. Thanks!
The television code and the code you need to programme into your remote to operate your TV are totally different things.
You need a list of remote codes for that specific remote - they are usually supplied with the remote.
Try these three first.
10650
11636
11650
If they dont work, post back with your EXACT TV model number and I'll find the correct code for you.
Oct 14, 2010 | Televison & Video
I have a direct phone # coming into AVAYA Definity Switch. I do not have any display options. The phone is a 6408D+. I need to know how to forward incoming calls to a cell #.
It looks like you want to turn on Call Forwarding. If you don't have a call forward button programmed/labeled, then you need to know the FAC (Feature Access Code) to manually turn the feature on. If you don't have the FAC codes, then you need to log into the Avaya Definity to get them. You can find get excellent remote Aaya support @ http://www.avayaurgentsupport.com/ for only $3 a minute.
Jul 20, 2010 | Avaya Definity 6408D Corded Phone
How do i use the call forward option?
Call forward or call divert, the same features just different names in some models of phones. Only the name of the service says that it is diverting calls. There is 4 situations for activation and can be activated via the mobile device or directly by entering codes on the display phone. The function codes and their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy ##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Nov 03, 2009 | LG VX5400 Cellular Phone
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
When operating duratrax evader ext truck goes forward when told t
Check the servo reversing switch on your transmitter,or swap your motor wires. Hope this helps
Jun 28, 2009 | DURATRAX Evader Electric Truck
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  7. Note:
Feb 11, 2009 | Zenith ZN-501S Remote Control
How do you turn off phone forwarding? Somebody inadvertently has their phone forwarding to another extension. Lucent Partner 18d.
It depends on the kind of telphonesystem and the kind of forwarding.
Generally the procedure is #code# where code is
21 for call forwarding unconditional
61 for call forwarding on no reply
67 for call forwarding when busy
On most mobile operators you can do #002# or ##002# to take the all in one go.
On some fixed (analog/PSTN/ISDN) lines you can use #001# to take them all inone go.
Some PABXes(officephones) also have call forwarding on precense (lunch, meeting. etc) and this is often turned off with #23#
Apr 01, 2008 | Lands Phones
Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset Logo
243 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
