Question about LG GCC4522B CD-RW/DVD-ROM Combo Drive
I lost my ASUS P5B installer CD
I need help...
    President:
  • 1,179 Answers
Go to the asus website, www.asus.com; click on the support link, lookup your specific model # & input the operating system you are using. A list of all available files, software, drivers will appear. Download & install the drivers/files you need and you should be all set. Hope this helps.
Posted on Jun 01, 2009
ASUS P5B TMX HD AUDIO FAILURE
Try installing the latest audio driver.
You can download the audio and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 04, 2012 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
Motherboard P5B-TMX-GB-SI diagram need to add addition RAM could do with contact numbers
DDR2 Upgrade for the ASUS P5B-TMX-GB-SI Motherboard 4GB kit (2GBx2), 240-pin DIMM, DDR2 PC2-8500 memory module
Part Number: CT2KIT25664AA1067
Guaranteed-compatible with the ASUS P5B-TMX-GB-SI
http://www.crucial.com/store/listparts.aspx?mfr=ASUS&model=P5B-TMX-GB-SI
you can see all of the crucial updates for this motherboard ram
hope this helps
2q==
Jun 16, 2011 | Computers & Internet
Hello, I have a problem with my audio driver for Asus P5B SE Motherboard. My 5.1 Logitech X530 sound system doesn't work very well (only the two front speakers working). I probably need to change the...
I was also facing the same problem
1. Universal audio architecture which will enable your motherboard to detect audio driver it can be downloaded from here
2.Now try to download the latest audio driver from here
Jan 27, 2011 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
User guide for a p5b-vm many thanks rob selsig
heres a link to the support site http://support.asus.com/download/download.aspx?model=P5B-VM&SLanguage=en-us
You can then click on manuals and choose the manual in which ever language you require
heres a direct link to the English version of the user manual http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2833_p5b-vm.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | ASUS P5B-VM Motherboard
P5b-vm se asus driver
You can download the drivers for your motherboard from asus here:
http://support.asus.com/download/download.aspx?modelname=P5B-VM SE&SLanguage=en-us
just select your operating system
Mar 31, 2009 | ASUS P5B-VM SE SKT775 G965 MATX...
Asus P5B-E motherboard won't resume from hibernation
You may want to verify your bios version and perhaps download/install an update from this page. It's worth a try to see if it clears up the problem.
Mar 16, 2009 | ASUS P5B-E Motherboard
AHCI
choose RAID mode.. that should enable AHCI. (as per wikipedia) on your motherboard so that means.. that if you're installing the os on this hdd you may want to use the raid driver for it which is likely what's in the ASUS cd you got so your os get to use the hdd as it's meant to be used.
you may also want to make sure you're using the right sata connector on your motherboard: check page 33
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2642p5b-vm.pdf
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B-VM
the problem could laso lay in your cables.. it's know the average may be affected by faulty SATA cable or faulty SATA power cable (powersupply issue)
you may also want to run a backup of your data and then run a defrag and a checkdisk on the drive, and it's probably also worth it to rung Seatools (download from this page: http://www.seagate.com/www/en-us/support/downloads/ ) to check the health of your hd.
Also try to update the SATA controller drivers or the motherboard chipset
lastly, post the results of your tests here on fixya or better yet: in here: http://forums.seagate.com for further follow up.
try each recommendation one at a time and then test the speed of your hd to see if there's improvement.. make sure you back up before you do anything drastic.
good luck (it took me 2 hours to pos
Dec 14, 2008 | Computers & Internet
P5B-E errors after XP re-install
on the issue of cd drivers ,you have to work with the ide cables,try to change or even try new ones
Nov 11, 2008 | ASUS P5B-E Motherboard
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
LG GCC4522B CD-RW/DVD-ROM Combo Drive Logo
762 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
