Question about Toshiba REGZA 47HL167 TV
Two DVD's stuck in Toshiba Regza with built-in DVD player
Last year I purchased a 32" Toshiba Regza with the built-in DVD player, model 26LV67. Tonight my helpful 4 year old inserted a DVD into the player while another DVD was already in. Now both are in and I can't eject either. Any suggestions on how to remove them?
  • 47 Answers
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Posted on Jun 25, 2009
  • Anthony Ponce
    Anthony Ponce Dec 28, 2013
    Disk LED in front of TV blinks 3 times then does out but there is no dvd in player... Now the TV wont turn on
Is it ok to turn a Toshiba LCD TV off at the power point to save a little electricity? We have a circuit breaker adapter board which runs 5 red LED's at night (TV, DVD player, sterio, surround sound...
Yes its fine to turn the power off at the power point. In fact this saves money because there is no idle appliance power drain. It is also a safe practice to disconnect the power at night or over longer periods of inactivity because there have been instances where plasmas in particular have caught on fire. Turning the power off will not affect your friends LCD TV they are designed and built by engineers who incorporate power surge protection. The circuit breaker should be one of very good quality and if this is the case then your friends LCD will be fine.
Jul 12, 2011 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
The disc is stuck in my dvd player and won't eject..
Look for a small hole on the door of the DVD player. Get a paper clip, unbend it and slowly push it into the hole, apply some pressure and the door should pop open.
Mar 05, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba Regza 32LV67U DVD player won't play DVD. put dvd in, it makes 3 attempts to read then spits it out. Can I fix this or is this a take-it-in for service issue?
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc.
Jan 27, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Can you connect a cd/dvd writer to a toshiba tv
I don't think you can because you would still need to have a program to tell the burner what to burn. You can purchase a DVD burner with HDD on it, kind of like a stand alone TiVO plus dvd burner, but I don't think you can burn from a TV like that.
Good Luck,
NOLA Tech
Jan 29, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My Toshiba Regza 32 inch lcd tv has a serious problem, on occasion the screnn will turn a fuzzy green color and turn itself off, usually a few loud popping noises also occur after it shuts off then the...
Model number means EVERYTHING to a real technician...
As a guess the popping noise could be arcing to ground - maybe from the inverter or one of the transformers on the inverter. The fuzzy green could be decoding the t-con board is attempting as this ground fault happens and shuts the unit off... I' would clearly have this checked before it does some serious damage. An ounce of prevention could save you pounds of cure....
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Toshiba REGZA 46RV530U LCD TV
Toshiba Regza 32 inch with DVD player - won't eject
Disconnect cable from DVD to TV, press play, and then press stop, try to push eject button to get the disk out. If all could not have, you have to open the DVD cover then get the disk out.
Aug 18, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Wife put another DVD in 32" Regza LCD with DVD, now 2 are stuck
Open it up. Once opened they are pretty easy to figure out.
Jun 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
TOSHIBA 26LV67
Yes, go to www.toshiba.com to check all the specs on your model.
Dec 08, 2007 | Toshiba 26LV67 26 in. LCD Television
Toshiba REGZA 47HL167 TV Logo
553 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
