Question about Acer Aspire 5315 Notebook
CPU compatability My Acer 5315 has: Socket-P Intel Celeron 550 2GHz, 533MHz FSB, 1M cache I was thinking of upgrading the CPU to: Socket-P Intel Core 2 Duo T7500 Merom 2.2GHz, 800 MHz FSB, 4MB L2 65nm How can I find out if the motherboard can handle it? (...and is this a good decision?)
  • Jubei
    Jubei Jun 01, 2009
    I keep getting different answers on this topic, one is that it only takes 533MHz and the other is that its possible but will heat up the computer more than normal...
    MORE INFO PLEASE
  • Jubei
    Jubei Jun 01, 2009
    Thank you for your help. (^_^) V,,
    President:
  • 1,179 Answers
It is not compatible. If your fsb is 533mhz then any replacement cpu would need to be a 533mhz fsb chip. This is unless your motherboard supports different fsb's. You will need to check your manual or the manufacturers website to see what cpu's your system supports. Hope this helps.
Posted on Jun 01, 2009
  • Roy Lonsinger
    Roy Lonsinger Jun 01, 2009
    The manufacturer's website should have a cpu compatibility guide that will tell you which processors your motherboard supports. As to the other issue of fsb, it depends if your motherboard supports higher fsb's than 533. Some support more some are locked at 533 so it again depends on the board your computer manufacturer used. It should be listed on you system build sheet that you got when you bought your computer. If not it should be available on their website. If all else fails & you feel comfortable opening up your system you can get the part # or model # from the board itself. You can put an 800 mhz fsb cpu in as long as it's the same socket type but be forewarned if your board is one that has a locked fsb then your newer cpu will operate at the slower speed making your purchase basically worthless. Hope this helps.
CPU upgrade for Compaq SR1220NX Desktop
Here are the CPU specs that will help you find a new CPU for your desktop:
Socket 478 for Intel P4 Williamette and Northwood processors
  • Supports Intel Pentium 4 processor up to 2.8 GHz
  • Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)
Oct 14, 2014 | Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Best cpu upgrade
The Gateway MX8738 Notebook PC uses an Intel Pentium Dual Core Mobile T2060 processor.
http://support.gateway.com/us/en/s/Mobile/2007/SonicC/1014366R/1014366Rnv.shtml
{ Look under Specifications, and Components }
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#Dual-Core_Mobile_processors
Yonah Core based.
Built on the 65 NanoMeter technology. (65nm)
Front Side Bus frequency rate is 533MHz. (FSB 'speed' = 533MHz)
Voltage range it can operate on is from .0762 Volts DC to 1.30 Volts DC
Uses the Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
The motherboard chipset is an Intel 943GML for the Northbridge chip, and an Intel 82801GBM for the Southbridge chip.
(The Southbridge part number is Intel 82801GBM. It is also referred to as ICH7-M.
Also scroll down to the heading - Southbridge 9XX and 3/4 Series Chipsets. ICH7-M ),
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_mobile_chipsets
Bookmark the above chart, I'll be referring back to it.
This is a motherboard diagram for the technology used for your motherboard, in the Gateway MX8738 Notebook PC,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Primer:
The motherboard chipset technology used in your laptop is a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip handles the faster capabilities of a computer.
Supports the Processor, Ram Memory, and High-speed graphics.
[ High-speed graphics being AGP and PCI-Express.
Does Not apply to anything connected to the PCI bus, or Integrated Graphics.
These are slower processes of a computer, and are handled by the Southbridge chip ]
The Southbridge chip handles the slower capabilities of a computer;
Anything to do with the IDE bus, SATA bus, USB bus, Ethernet, and Audio. (Sound)
Therefore you want to look first of all at what processor socket it has, what processor was already installed, and what the Northbridge chip is.
1) Socket M processor socket.
Your replacement processor has to fit in a Socket M processor socket.
2) You know that your BIOS supports an Intel Dual Core processor, and the Yonah Core technology.
The replacement processor has to have a 533MegaHertz Front Side Bus. (533MHz FSB)
Has to operate with .0762 to 1.30 Volts (DC)
3) The Northbridge chip is an Intel 943GML.
Looking at the chart you can see this Northbridge chip will support;
A) Celeron M (Eeech!)
B) Core Solo (Bleech!)
C) Pentium Dual Core
In the list the Pentium Dual Core is the best option.
{ The Celeron M has HALF of the L2 cache that a comparable Pentium M would have.
The Core Solo is just a glorified Pentium 4. It's a Single core processor }
Has to be a mobile Pentium Dual Core that uses a 533MHz FSB.
Based on the Voltage, FSB, and processor socket used (Socket M), the Intel Pentium Dual Core
model T2130, is the best processor your motherboard will support.
What are we talking about here?
You would be going from a processor that operates at a maximum frequency rate of 1.60GigaHertz, to a processor that operates at a maximum frequency rate ('Speed') of 1.87GHz.
Not enough of a performance boost to waste your hard earned money, or time on, IMHO.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2011 | Gateway MX8738 Notebook
What is a version of Biostar G31d-M7
Socket LGA 775
Supports Intel Core 2 Duo/Pentium Dual-Core/Celeron Dual-Core/Celeron 400 Series Processor
Supports FSB 800/1066/1333MHz
Support Intel Hyper-Threading Technology
FSB 533MHz is not supported by this motherboard. CPU TDP over 65W is not available. Please refer to CPU support for further information.
hope this helps
Mar 02, 2011 | Biostar G31D-M7 Motherboard
Hi all i have a little question about CPU IN A9RP
if it will fit in the cpu slot, you can. But beware all chips have different number of prongs and only the chipsets that fit the number your slot has labeled on it. You have to some reasearch.
Sep 03, 2009 | Computers & Internet
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Oct 03, 2007 | ASUS P5S800-VM Motherboard
Acer Aspire 5315 Notebook Logo
464 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
