Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
When the cycle starts F1 appears on the dial,
We clear it and it appears again later in the cycle. It now doeas it with each load. I HAVE THE SAME f1 CODE AT THE START AND AGAIN AT 21 MINUTES. wHAT IS THIS CODE AND WHAT CAN BE DONE?
    President:
  • 272 Answers
Here is a link to the service repair sheet at Whirpool for the F1 error code on your machine. You will find 4 things to check at the bottom of the page. Good luck.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/1a4cb9c9ab426640852574e90050e40f/$FILE/8178767.pdf
Posted on Jun 01, 2009
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
After a power outage the oven does not work and F1 code appears.
the F1 code is a universal service code to ALL brand ovens and it means that one of the buttons on the touch pad has shorted out. You can clear the code by pushing clear/cancel button and if doesnt reappear it was fluke, if it reappears within 15 minutes and once again you push clear and that cycle repeats, the touch pad must be replaced
Good luck,
Gene
Jul 26, 2011 | Ovens
F1 flashes on my maytag bravo washer
This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Washing Machines
My washer beeps and says "F1", I press STOP and START. "F1" appears again and I press STOP and START and then works. WHat does this mean?
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I just had the panel rewired fro f51 now i have f1
F1 is a primary control failure. When I get my F1 I hit pause/clear and then start - it usally begins its cylce then bumps back to F1. If I do this about 3-7 time it will clear. Then on rinse we go again. Some days I have a 3-F1 restart and somedays it is a 7-F1 restart. Just depends on the day. No rhyme or reason. I know I have to replace the main circuit board but $160 + labor is not what I want to do, so I fuss over the F1 and move on.
Feb 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
call mfg. i heard they are fixing this problem even washer is out of warranty. to solve this problem your washer need new control board.
May 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Apr 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The machine flashes f1
Hello madelinezak
Welcome
F1
“F##” code
Press PAUSE/CANCEL once to clear code. Press START. If
code appears again, call for service.
Thank you, Huuum
Please remember to leave a rating
Oct 12, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
255 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
